Garrard Zero 92 Idler
eb2jim
A couple of quick question, hopefully not too hard to answer. Do the Zero 92 and SL 95b share the same idler wheel? Also, does anyone know the aftermarket idler wheel code for these turntables (i.e. 1499-??)? Thanks!
The SL95B and the Zero 92 should share the same idler wheel along with the model 82 and the Zero 100, Zero 100S and Zero 100C (But not the Zero 100SB which was belt driven).
The Garrard part number was 75625. www.turntablebasics.com referrences the idler to part IW08.
If the idler needs replacement, rebuilding is an option. Many A-Ker's swear by the work by Terry's Replacement Rollers. His website is www.terrysrubberrollers.com.
