Kt77
Well-Known Member
Way to go!!!!!!!!. Have fun.
I think I'd stay with Norne/Norse cables...they're state side, and have more options, but good looking out! very much appreciated!
Question, bro....are you suggesting UPOCC and OCC are different? I hope not, OCC is the short cut.
_ohHere's another head ups for you as you're into ripping from said M Mini, that should come in handy:
http://www.digitalaudioreview.net/2015/03/dbpoweramp-comes-to-os-x/
Thanks for the additional link...Havent found if they're state side tho.
But just to note, I don't see where you're coming from with the previous links.....OCC and upocc are one and the same process. And from what I've read in those links, they are using the terms interchangeably. One is not greater than the other as far as processing. Just interchangeable in the way its said. But there are different company's that sell such types of cables and may put their own spin on the OCC. Example....Analysis Plus still has the hollow design with their Crystal Copper. Others like to use the "Litz" design....some like to even Cryo their OCC and so on. I've been into UPOCC for about 10 years now and have always upgraded all my cables to it as time permits. I've also been preaching up OCC for years....now others are starting to listen.:yes:
From what i have been reading all of these companies are doing pretty much the same thing, organizing, tagging, and ripping and each claim their way is better. The main difference seems to be user friendliness.
So i have several questions. Why do some use several of these services, it seems this complicates things even more. Second if i used a trial run of lets say JRiver and at the end of the trial run decided that it was not for me, what happens to my music on JRiver? Since JRiver would not be enabled how would i have access to it? Thanks.
Great point, and seemingly a rather true one at that.
But let's allow those whom actually rid their CDs onto such devices respond, as I haven't done it in years. But speaking on the music library matter - I've remained with iTunes since 2006 as a means of cataloging or storing my songs and once placed there other then a few that were altered - I still have access to them, from what I noticed JRiver merely found my music which I already had placed onto the Apple Remote as well as iTunes and pulled it onto the JRemote device while not bothering it.
It's also wise at some point to back your music up onto separate external hard drive devices, I like the ones by G-Technology - Toshiba along with two others that escape me at the moment due to the fact that are made from aluminum and match the styling of the Apple products to a " T " which I find creative in that sense of synergy as appearances go - yes..........., I'm into modern decor and love Italian furniture and minimalist clean lines, so be it.
But that's my take on said issue, I hope it helps.
Every little bit helps and it`s much appreciated.
I did find a late 2012 Mac Mini so that`s in house and set up. The Amber has been finished and is going thru testing. I guess i could start ripping CD`s and adding music to the Mac Mini while waiting for the Amber.
I have been looking at these for storage and backup. http://eshop.macsales.com/shop/ministack
Just a heads up, so you'll know how to eject the disc in question ( near bottom of article ):
http://www.runaroundtech.com/2012/05/08/review-apple-superdrive-for-macbook-air-and-mac-mini/
Thanks!!!!
I don't think things have changed much with ver-20 but here is the instructions for ver-19.
http://yabb.jriver.com/interact/index.php?topic=82074.0
It's worth noting that Jriver uses their 'DSP engine' to get to DSD128 meaning it's going through a PCM stage. Perfectly fine (IMO) if you are starting with PCM anyway but if you have a native DSD64 file I'd just play it bit-perfect - don't think it's such a great idea to go from DSD>PCM>DSD just to get to DSD128.
Just my opinion though - try it both ways and draw you own conclusions - they are just different shades of good sounding.![]()
Just got a call from DHL and the Amber arrives tomorrow!!! Christmas comes early.
