Thanks Oscar for the support, and thanks to the fellas as well for the kind words.
Big guy! What up!?
Man, sounds like that's a fair well note? Naw, bro...it's never fair well, but "in a minute"!
Still hanging with the cables, I see. That's cool. Bro...if you've the new iUSB power supply, you don't need the iPurifier2. The iPurifier2 is for those who have the first generation psu. So you good, bro!
Bro...you mentioned DACs. I'd like to report, I've heard one of the best DACs I've ever heard the other day...actually it was my second time hearing it. All I'm going to say is..this DACs is solid state....and it sounds every bit like tubes. The name of he company that makes the dad is sold through Legacy audio....yeah that's right! Steve got his new speakers...the "V". And it comes with the Wavelet DAC. The Wavelet is more than a DAC...it's a preamp and room correction device as well, but I think they sell the DAC alone as well. All I know at the moment, it came with the $50k speakers my buddy purchase and the DAC sound better than any DAC I've had the pleasure of sitting in front of...and get this, it wasn't doing DSD...I could tell it wasn't DSD, but it was still all that.
In a minute, bro!
I agree.Okay fellas, I'm about to test Byron's hearing by sending him what I hear as a remarkable USB in that Neutral Cable basic version ( the blue one ) that set me back $150 shipped from Italy, as mentioned to B..........., I've come across what I hear as great investments in sonics at lower prices from the likes of the AudioPrism QuietLine ( which lead me to investigate Isotek Systems Neoplug and prefer them, as I only need a total of 3 in or around my system ) - an Oyaide R1 AC Outlet - and said USB Cable, which have in hindsight all capable of taking the sonic level of my system that much closer to what I now consider a synergistically balanced approach beyond anything I'd have imagined short of having spent an extra $30.000.
While many discuss the importance of line distributors/conditioners very few really mention noise filters that actually remove unheard, yet still present sounds as they contaminate our mains, but it's upon inserting said devices like the QuietLine or PS Audio Noise Harvesters along with a few more costier units that one becomes aware of what's been missing the whole time.
While I don't might spending say $1.200 on a great sounding IC that matches my system, it's when I come across these simple, yet effective devices for less then $200 - $300 that cause me reason enough to want to share my joy. Anyways, I'll be sending the cable off to Byron on Thursday, and have told him already..........., I only took me a mere 5 minutes to know that I couldn't go back to the WW Staright 7, or even their more costly version called the Silver Platinum 7 which this was compared to, and it was returned the following morning, as I didn't need 10 days to hear what was to my ears a purer - truer sense of tonality and balance that caused me to sit there for 13 hours just amazed at what was obviously right about this design, and where others should be made aware.........., but I ask that you sit back and await Byron's findings for yourselves - good, bad or indifferent, only time shall tell.
Enjoy the show.
I agree.
The higher resolution your system is the more it will benefit from cables and power conditioners-the Audioprism units are great. Many times these systems are much more susceptible to "inperfect" conditions, impedance matching, and cables. But that's the price you pay for "truth to the signal".
If you try using the Audioprism Noise Sniffer-you will easily understand how noisy your lines are. Even a corroded wire, or subpar switch can add noise-above your noise floor. IF you can borrow one-try switching in a cheap power cable for a nice shielded one. Bad ones can easily add-8-10db of noise.
Plus-not to mention how this noise may interfere with the signal itself. It also clearly audibly shows the benefits of using the shortest possible power cables.
Add to that, some equipment, particularly digital equipment will bounce back noise into the line. You might be surprised-even with expensive units, can add some bounce back. The Audioprism filter usually solve this-or bring it below your baseline noise floor.
With mid/lower hi-fi stuff, switching out cables probably won't make much of a difference, but proper filtering should help drop down you background noise.
The nice thing about the Audioprism and MIT units are they are parallel, not series so they won't restrict current.
You still may want a good surge protector as well, but you need to pay attention if your equipment is current happy-many will degrade the sound with too many chokes/etc if they can't supply the proper current.
I have heard too many REAL high resolution systems, and the differences well made shielded cables, and power conditioning to make a foolish remark that its snake oil.
If it didn't make a difference on you system-it's probably a midfi/low resolution hifi setup.
Nothing wrong with that-but at the same time it's foolish to say they won't make a difference on a different setup.
I loved Stereo Review-but it's funny how this mis information has carried on since the last issue in 1999. And how steadfast people stick to the idea a wire is a wire. Try using a Noise Sniffer, for example, and explain the differences in the noise...
You need to look at cables and power conditioning as component's themselves, and take as much care as you did selecting your 'hardline' components as you do the cables and the power they will be using. Otherwise IMHO your really wasting you money as you will never truly hear what they can do.
Thanks for your response, as it's so reassuring for me to see that someone actually " gets it ", as it seems I've tried for several years now to share solid recommendations with others, yet get the overall impression I'd be better served taking to the wind, as I'm to assume most are to set in their ways to even imagine what's missing without having heard what these devices bring to the clarity and purity of the musical notes themselves.
Yet I've also come to the realization, that as long as I've taken it upon myself to understand the importance of enhancing my entire system via said devices, resonance controlling footer and platforms, and the likes, as I'd much prefer to focus my attention on the details of what these devices bring, as opposed to merely feeling the desire to buy newer components every other 2-3 months, without in fact knowing how to get the best out of the ones I've in-house to begin with, as there are often times when one merely needs to understand how to obtain better sonic resolution and integrity from any given component or system and not write items off so quickly without applying effort to said cheaper, yet just as vital means of bettering ones fidelity without moving lateral onto a diffent, yet not always better sounding component just for the sake of slight differences at best............., yet like with my own children, one gives them the best schooling and wisdom one can offer, it's then upon them to build their foundation upon the tools and choices their parents have given them and grow to become more productive members of society, and not sit back in years to come claiming they never had a chance of achieving anything..........., when all that's needed is, they pay attention and be willing to grow.
Yet more often then not people tend to challenge ones opinions, on what they themselves merely don't understand, nor have tried enough to see whether or not it's true to begin with, but I can say that my days of trying to share said details are far behind me now, as I'd much rather spend what's left of life enjoying my family and closet of friends in prolonged and long overdue listening sessions, then continue wasting my breath on those whom wish to remain closed minded.
I'm done, life moves onwards and outwards........, but I'm glad to see once again, someone gets it!.
Sure.
I think trying to 'educate' people directly is a waste of time. some has to do with the frontal nature, especially of late, people tend to get needlessly offended, or offensive (disrespected?-never got that one-(in my book respect is something you earn over a period of time-it's ain't automatic folks-sorry to say)-especially these days of the internet-and the rising of the "Close Mind Syndrome, a symptom of the former.
However documenting (here) these findings IS a great way of doing so-more or less mike a book, and will surely be helpful to those with more open minds, despite the nay sayers and trollers-dam them 'stinkin torpedoes.....as you mentioned most have never really tried to experiment IMHO-and it's usually very easy to see through-they are not being truthful. Harder to confront directly of course-but with a little thought and perspective you can point it out.....
They seem find joy in throwing a wrench in the works, while offering little constructive help. Lack of taking their life education seriously and lack of realistic personal and social perspective seem to be the main culprits.
Sad state of affairs I must say-but keep writing-the show must go one my friend! Honest information and reflective opinions are always helpful in this cat's book!!![]()
No-I'm using one Jitter Bug-seems to have some improvement.
Use it with a HRS Streamer III and really like the sound in my setup in the living room.
Some consider the HRS a low end unit-but it has a smooth and detailed sound, and benefits from a good input cable, and patch cable-don't cheap out here. It also has no need for outside power supply, the bass response is good.
For me it has that even non fatiguing sound-with plenty of detail not to get bored. Till I get more into computer/streaming this unit serves me well, and is a bargin IMHO for the $110.00 asking price.
I was demoing my Audioprisim noise sniffer-with a handful of Quietline III filters to a audiophile friend of mine (he has around 25K of Macintosh/Magnepan/cables/PowerPlant,) and he was totally dumfounded by the results of these inexpensive filters.
If you have not tried them, your missing something.
The Noise Sniffer shows how well the work. but if you put at least 2 on you circuit feed your system you will clean up the noise in the line nicely.
I also have a few in the kitchen in utility room, to clean up adjacent lines.
The Noise Sniffer also works to tell you how well your 'isolated" noise filters are working on your conditioner, as well as it's overall filtering effectiveness.
Especially if you think your digital system sounds a little bright and smeared-these inexpensive wall wart filters may do the trick.
The inwall MIT Z Duplex parallel filter also works very well-so well the Sniffer is dead quiet on high. Plug your amp into one outlet, and plug in a Isoblock for surge/ isolation on your source components a ferrite ring on your digital components power cable, and your set for a good baseline.........
Getting a inexpensive db meter from Parts Express is useful in getting a baseline for the noise in your listening room.
People are always amazed when they find there powerline sounds like a hive of angry bees.
Amazing component, and diagnostic device.
ok, been off this thread for a while. what is the word on the new offerings from ifi? I have the Nano dsd, but am considering upgrading. how much of an improvement am I looking at here with staying within the ifi line? OR, should I look elsewhere?
