I currently own a R-2000 (well restored). Had it for nearly two decades. I like the SQ, it’s unforgivingly detailed and clear in all frequency ranges, even at lower volumes, and has enough umph to power my large, open, heigh ceiling loft space.
I recently changed things a bit and added Wiims for streaming and for adding WiFi for remotes.
I am debating on selling my two receivers and replacing them with an integrated amp.
What integrated amps (vintage or new) would give me a similar SQ or better?
Budget? It depends: If SQ/power is on par with the R-2000 max $ 1’2000.00 - if it’s a significant upgrade maybe 2.5K max.
I should mention I prefer a clean vintage look (and large meters would be an added bonus).
Sources all go through a simple switch into a Wiim Pro+ and from there to the R-2000.
Spotify, Tidal; Technics TT (Ortofon OM30, Pro-Ject Box S); NAK Tape; Denon CD…
Analog/wired: 2 x KEF Q500 and a Klipsch sub; remotes: 2 x Fluance A61 (Wiim Mini, WiFi) and 2 x JBL 401-BT (Wiim Mini, WiFi).
Some components may be upgraded over time.
