JMelton
In the end would you want someone to pick your soul mate in life?
Some choice as best left to one's self.
I suspect someone else could have done this better for me
I do agree the point seems to be clear: OP does not like.
I'm unsure what the original poster wants other than to explicitly trash Grado. He obviously doesn't like Grado and is really upset about having spent $75 on one. I'm sure he can sell it although not likely get the full $75 back, especially since he's modified it. But, $75 doesn't last me long in the casino and life's too damn short to fret about a few dollars.
As others have said sell the cart, it is a bad compliance match for your arm, probably a few of your carts are if they are P mount, look for carts that match the arm better or a damper. Impossible cant get such a massive compliance miss match to work well it is always going to sound muddy (high compliance high effective mass typical symptoms). Like I said from the start there are options to make it work better but you have not even asked what they are and some of us have hinted there are solutions but you seem uninterested so myself and others have not gone further to help as clearly you dont want that help.
Chris
Point taken, you are unhappy with the Grado!
Feel you wasted money!
Sell it and move on in your journey thru audio.
Trust me in this and any hobby for that manner, there will be plenty of times when trying out gear this type of occurrence will be the result.
Plenty of others out there with different opinions, likes and dislikes.
Stop. I bought a new Grado2 based upon what I had read on here. My hope was it was better than the others I had. THAT is why I bought it. I certainly didn't blow $75 just for grins and giggles. And I didn't 'modify' anything either. Sheesh!!
Did I read this post incorrectly?It's too big. I had to sand the plastic off the top to make mine fit (and that was with about 7 different adapters of all makes).
I use Grado on two tables at this time. Like them or would not.
One of the tables is a JVC QL-55F works sounds great. Use a scale for setting weight and table has damping adjustments that may help.
LOVE my JVC QL-Y55f's (I have two of them actually!). I didn't care for the Grado on that either.
I found that my Jelco arm weight adjustment was off some time ago. Now use either my old trusty Shure or a digital scale. It does make a difference!Sounds like your just not a Grado fan.
Nothing right or wrong in that.
Yes the JVC is a very nice table.
What cart do you run on yours BTW.
I checked the weight adjustment on mine only to find it was off so set using a digital scale.
No it is not, how many times! P MOUNT SHOULD BE HIGH COMPLIANCE P MOUNT SHOULD BE ON AN ARM LESS THAN 10g EFFECTIVE MASS. Grado are high compliance some P mount are not Grado in this respect are correct not wrong. Your arm is 22g!!!!! It is not correct for any P mount that is within P mount spec. Some P mounts worked with heavier arms but Grado compliance was always high and always P mount compatible.Jesus Chris! It's a p-mount mismatch on Grado's part, period.
Maybe you should let this goMan it is like pulling teeth!!!
Chris
Oh no you didn't! Now it's ON! I love my Orto 2M red!I only really ever heard one cart that made me wince and run for the volume knob that was the ear bleeding 2M red...
Chris
Compliance of your arm effective mass is 7.5g which is less than half what the OP's turntable is. Yours is dedicated P mount which is why Grado compliance is correct for it.Maybe you should let this go
For what it's worth, I really like my Grado pmount. It's on a Technics SL-QD33 so not really sure if the compliance is a good match, but it is a "pure" pmount turntable, no adapter![]()
I will get my shooting ear protection and come round for a listenOh no you didn't! Now it's ON! I love my Orto 2M red!
Actually joking aside, the 2m cart itself is probably not a bad cart, it will never make my top 10 but the improvement that the blue is over the red points to the red having quite a poor stylus as the rest is the same so the sibilant high issues are for sure just stylus tip quality.Oh no you didn't! Now it's ON! I love my Orto 2M red!
Chris
Maybe, my ATC scm 100's are very detailed and neutral so if a cart is harsh sound is harsh. I did not keep the 2m red, really hated the sibiance, which us a shame as I have a microscope now and I would have liked to examine the stylus to see what issue was.A lot of people must upgrade from a manufacturer-supplied red at LP Gear. They sell the ones they've pulled for $75 which is why I own one: heavy discount, new cart
I found it sounded way too bright new through a new Onkyo amp and new Q 3020i speakers... but moving it into a different room with 15 year old Polk speakers and a 10 year old Yamaha amp tamed down that brashness. I think you need something warmer, older gentler... uh... dead-er (?) and then it's not so harsh but simply "full range"![]()
