Outlaw,
Thanks for the quick reply. Let me respond to your points.
Do you have a separate ground wire for the audio?
I am using the ground wire that is in the signal cable (5 leads, one of which is ground). This wire is tied to the motor case and the turntable plinth (metal on an Empire). It is connected to my integrated amp.
Make sure the TT is plugged in
It has the same amount of hum regardless of plugged in or not, reversed plug or not (yes not polarized), and regardless of whether or not the motor is on.
I'm assuming it's vintage and not a polarized plug; so try reversing the power plug, both on the TT and the amp. if the TT is plugged into the amp, you may need to try it twice as you reverse the amp's plug...
I tried reversing the amp plug as well, but no difference.
if all else fails, try taking the cart leads and winding them into a twisted pair.
If you are saying I should tie the two signal grounds together, I will try that. If you are saying not to do that but to twist the leads around each other, I will try that.
What I don't understand is why the hum changes from very very low to very audible depending on where the tonearm is positioned. (in the rest its quietest, near the spindle its more apparent.
