Grado hum mystery solved.
I think most Grado hum problems have nothing to do with what table it is mounted on, and everything to do with what gear is in close proximity to the cartridge. Keep your cartridge at least 24" from any other gear, and I'll bet your hum problem goes away.
I recently bought another turntable with a Grado on it. I have owned the same table in the past with a Grado - a Mission 775S. The other one hummed. The new turntable did not hum at all. No hum even at wide open volume, only the hiss of the phono stage. Weird I thought. What was different? Better wiring? It never hummed with Shure or Ortofons, so how could it be wiring?? Both tables had Grado Presitge series carts. One hummed and I hated it. The new one was nice and quiet and I loved it. I couldn't figure it out.
I had plans for the new table and the Grado and the tonearm were replaced. I took that Grado and put it on my JVC QL-Y5F in another system. Would it hum, I wondered? The JVC did not hum at all previously with the DL-110 on it, so I know the wiring/grounding is good. Also, I remember seeing this model in the Grado hum database and it's not a hummer.
I mounted the Grado and it did hum! What was the difference here I wondered? In the other system, there are no components under the turntable, it is a side by side rack config. In the system with the JVC, it is on a vertical rack, right above the integrated amp. Hmmm. Come to think of it, my old Mission table was on the shelf right above my amp. I'm seeing a trend here....
So I move the amp down one shelf, and move the CD player up one shelf to put some distance between the turtnable and the magnetic field of the amp's power transformer. That was all it took. Hum gone. Completely. The cd player doesn't produce enough EMI to make the hum come back. I'm happy and loving the warm Grado sound.
Lesson learned, keep any other components a good distance away from your Grado cart. I'll bet on most Grado hum problems are caused by other components being too close to the cart.
It is probably a wise practice with any cart to keep it as far as possible from gear that draws a good bit of current, because as a result it will create a stronger magnetic field than gear that does not draw much current.
