Grado MG ?
Old John
I picked up a Sony TT today that is from the mid-80s. It came with a Grado MG cart. I can't find any information about this Grado. Can anybody help?
Thanks
Old John
On the stylus assembly there are two dots, can you see what color they are? Also on the back section on the top of the cartridge body should be a date stamped somewhere in that area. It will tell you the date it was made.
The all one piece MG was reviewed a few times by different folks. Google it and you will find some info.
IIRC that cartridge is the mid-80s equivalent to the current Silver and is one of the top models of their standard "Prestige" lineup. That makes it a very good cartridge, indeed.
What attributes would you recommend for a phono stage to make the output for a Grado MG appropriate for Line In use? Feel free to recommend specific devices if you like. I am looking neither for ultra-cheap nor stereophile level stuff.
EXPLANATION: I am trying to set up a system for my daughter and have pulled out an old TT equipped with the MG. I also bought a streaming device, but find it necessary to use it's Line In not realizing this required a pre-amp.
Any standard phono stage will do fine, Grado's are very flexible (very low inductance, immune to capacitive loading). Spend as much as you feel appropriate.
