This is, I hope, a simple question. After reading lots of positive reviews, I've decided to go with a Hana moving coil cartridge. I still need to choose between the EH (high output) and EL (low output) models. My phono preamp is a Pro-ject Tube Box II, with these (fixed) specs for MC:
Input impedance MC: 100ohms /120pF
(while Input impedance MM: 47kohms /120pF)
Gain MC: 60 dB
Output voltage (typically) MC: 0,3 mV
While these are the specs for the cartridges:
Recommended load impedance: EL: >400 ohms; EH: 47k ohms
Output level at 1kHz: EL: 0.5mV; EH: 2.0mV
Up until now I've used a (now deceased) Denon DL-304, with a 0.18mV output, without complains. So I know the 60dB gain of the Project are good enough for the EL -which, I guess, would be the better option in terms of sound quality. But, and this is my doubt, what about the impedance? Keep in mind I cannot change the loading of my preamp.
Any help will be warmly welcome.
PS: Or, else, should I just go with a Denon DL-301 mk2?
Gain MC: 60 dB
