dougthechug
I recently completed recapping one of these units and this thread has been a tremendous resource. Going though voltage checks, the power supply tuner and preamp board is only putting out 19.2V where is should be 21V. I'm a beginner hobbyist in the vintage audio repair arena. I have not changed any components on this board except the 2 capacitors. I am getting good +32 and -32 from the first power supply board. Everything seems to be working well with the exception of low volume on the phono section. I know the phono section typically has a lower volume but it seems a bit excessive in this instance. Normal moderate listening, I'm at about 12 o'clock on the volume dial.Work in progress...
Power Supply
The H/K 630 has two power transformers, three small boards, and five chassis mounted filter capacitors that make up the power supply. The three small boards are identified as "Power Supply Circuit Board", "Power Supply (Tuner and Preamp)", and "Regulator Circuit Board". According to the service manual the "Power Supply (Tuner and Preamp)" comes in two versions. My unit included version 2 so that is the one I'll be discussing.
H/K 630 Power Supply Schematic
H/K 630 Power Supply Circuit Board (Board 1 of 3)
H/K 630 Power Supply Circuit Board Diagram
H/K 630 Power Supply Circuit Board Diagram in stock form
Power Supply Circuit Board Parts List
C805/806 0.1uf 400V Oil caps >> 0.1uf 400V Polyester Film
D801/803 1S1850R rectifier |<- ->| dual, common anode >> MUR1620CTRG 200V, 8A per leg
D802/804 1S1850 rectifier ->||<- dual, common cathode >> MUR1620CTG 200V, 8A per leg
H/K 630 Power Supply (Tuner and Preamp) Version 2 (Board 2 of 3)
H/K 630 Power Supply (Tuner and Preamp) Version 2 Diagram
H/K 630 Power Supply (Tuner and Preamp) Version 2 in stock form
Error: TR802 - The pinout shown in the board diagram for TR802 is flipped 180 degrees. The front of TR802 should face the capacitors. The emitter should be on the left side closest C808 and base on the right side closest to C807.
Power Supply (Tuner & Preamp) Version 2 Parts List
TR801 is heatsink mounted with a live collector tab and needs to be insulated. Be sure to save the original insulating washer that is specificlaly designed to fit the heatsink when installing a replacement. The board diagram doesn't show the capacitor values for C807 and C808, but they are correct as provided below.
C807 470uf 35V 16mm >> 560uf 50V UPJ 16mm
C808 470uf 25V 16mm >> 560uf 50V UPJ 16mm
TR801 2SD234 TO-220 BCE >> TIP41C TO-220 BCE
TR802 2SC828 TO-126 (2SC495 pulled ) ECB >> KSC2690 TO-126 ECB
D805/807 S-05 >> Didnt change...possible sub 1N4007
D806 BZ-210 (21V 1W) >> 1N4740A (10V 1W Zener) & 1N4741A (11V 1W Zener) in series
R801 22K 1/2W Carbon Comp >> 22K 1/2W metal film
H/K 630 Regulator Circuit Board (Board 3 of 3)
H/K 630 Regulator Circuit Board Diagram
H/K 630 Regulator Circuit Board Diagram in stock form
H/K 630 Regulator Circuit Board Parts List
C809 1000uf 35V 18mm >> 1200uf 63V UHE 18mm
C810 470uf 16V 12.5mm >> 680uf 50V UPS 12.5mm
C811 470uf 16V 12.5mm >> 680uf 50V UPS 12.5mm
R802/803 150 Ohm 1/2W Carbon Comp. >> 150 Ohm 1/2W Metal Film
R804 820 Ohm 1/2W Carbon Comp. >> 820 Ohm 1/2W Metal Film
R805 100 Ohm 1/2W Carbon Comp. >> 100 Ohm 1/2W Metal Film
R816 22 Ohm 1/2W Carbon Comp. >> 22 Ohm 1/2W Metal Film
D808 >> BZ120 12V 1W Zener >> 1N4742A
D809 >> BZ140 14V 1W Zener >>
Is this all normal behavior and is 19.2 close enough to the reference voltage?
If not, which components should I be looking at on the preamp power supply board?
