One small question. I’m intimidated by changing the 4 adjustable resistors on the amplifier board. Could you explain those steps to us please?
So, you have to replace a trimpot. Here is an incomplete guide:
First, does the original trimpot have two legs? Or three? You should be able to tell from the board where it is soldered in or from the schematic. Two-legged trimpots are just variable resistors. Three-legged trimpots are potentiometers. (I may have the terminology wrong here; I'm just a hobbyist)
If your original trimpot has just two legs, then you'll need to buy a three-legged trimpot and intentionally short the wiper (middle leg) to one of the two outside legs. This makes it a variable resistor instead of a potentiometer. If you
don't short the wiper to one leg, then you have a
fixed value resistor. That is not what you want.
Example:
https://www.audiokarma.org/forums/i...arman-kardon-330c.781237/page-6#post-11943536
Example:
https://www.audiokarma.org/forums/i...ng-a-harman-kardon-330c.781237/#post-10810244
So, regardless of the original, you need to order a three-legged trimpot. Be very careful when ordering:
Many online parts sites (Mouser, I'm looking at
you) show little photos of trimpots, but the photo is not necessarily the same as the part you are ordering. For example. you may find there is a Bournes that has the right value, the picture looks like what you want, order it and learn that it has the pins with the wrong layout or spread. This can be learned.
Example of some layouts
https://www.audiokarma.org/forums/i...oration-and-recap.815087/page-3#post-11944007
Examples:
So, for our example, the Bournes 3386 trimpot is the type/shape/turns/whatever that we want, we've picked the right resistance value, and now Mouser shows 3-4 of the same-looking trimpot but each has a different letter at the end of the part number.
That letter is what you need to look up in the datasheet. Download the datasheet by clicking on the link at the parts site for that part, read the variant pinout styles carefully, and
then choose the model and part number/letter that will fit. Or fit closest.
And you'll want to use the diagrams in the datasheet to determine which orientation of trimpot do you want. Often you'll want the same as the original since that orientation should allow easy adjustment once the parts have all been soldered in.
"top" means you adjust from the top. "side" means you adjust from the side. You can choose a more convenient orientation, but check how much space the trimpot will take up on the board and how you'll get a screwdriver to the trimpot to adjust once the unit is back in operation.
The datasheet will also help you determine if you have enough space (on the trimpot) to roughly meet the holes in yur board.
