Nope. My ego isn't going to take any of this that seriously. I hope I have a sense of humor about this. Hey ... It's not my machine that needs work.. . . and terra1, I wasn't trying to poke fun at you, so I hope you didn't take it that way. That was my attempt at lightening the tone of some of the posts. My apologies.
I pointed out the fuses because the pm 640 was my first amp. I had to replace those fuses a few times it was twenty some years ago. and I dont think they were slow blow fuses I could be wrong ......had it teamed up with a pair of walsh 3s ..
I was surprised that I had to turn my soldering station to max temp before the solder would melt. And I did NOT practice on anything. I figured I've successful operated a torch on my roof with torchdown material, and I've soldered speaker wire, and transplanted an original tonearm on my AR XA turntable desoldering and soldering hairthin wires . . . so why not just jump in with both feet!!
So now I'm trying to figure out how to use my DMM. The instructions aren't so good, so I'll see what I can find online. So I have NOT yet adjusted the bias.
I did run the amp for about 30 minutes and the heat sinks did get hot, but not too hot for me to touch, and I had to get my hand down in between the sinks to get the most warm part.
One last thing. My DMM says something about a K type thermoelectric couple to measure temperature. I guess that is something else I would need to buy . . .
Thanks for the help guys!! I hope to report back as soon as I get the bias adjusted and take a listen.
Congratulations. :thmbsp:I was surprised that I had to turn my soldering station to max temp before the solder would melt. And I did NOT practice on anything. I figured I've successful operated a torch on my roof with torchdown material, and I've soldered speaker wire, and transplanted an original tonearm on my AR XA turntable desoldering and soldering hairthin wires . . . so why not just jump in with both feet!!
Don't worry, if this section confuses you, just follow the SM instructions on Idle Current adjustment and have a soda and forget this section.
The HK PM640 amp adjustment does not have instructions for adjusting DC balance, only adjusting Idle Current. But you can still measure at the speaker terminals.
So to give you practice using the multimeter, you may want to try measuring the speaker terminals before adjusting Idle Current and using the test points. This is what echowar's post on measuring DC offset is about when measuring at the speaker terminals. Hopefully left and right should be under 50mV.
Measure at the speaker terminals again after adjusting the Idle Current to compare.
echowar's post on measuring at the speaker terminals for DC and target levels
http://www.audiokarma.org/forums/showthread.php?t=5634
basically, speakers selected, aux, volume minimum, balance centered, tone control defeated
QUESTION: It appears that the solder on the board is different than what I'm using. I'm using a rosin core 60/40 by MG Chemical, but when I went back to add more solder it "burned" the solder and the new solder just beaded up into a ball . . . didn't do that last night, using the same solder at the same temp level.
So I left well enough alone. But moving forward . . . it would be nice to know if the 60/40 is what is on circuit board connections, or if it's silver. I have silver solder, and wouldn't mind learning how to use it if that means getting the clean look of the circuit boards on this H/K.
My Process: Since there was a good mound of solder on the wires, I was able to use it (recycle). It was very clean looking after melting, so I was able to add to it, but I was not effective in using the desolder bulb, and I had a technique developed which allowed me to get the old resistor out using my suture clamp on the wire (top side) and going back and forth melting each point until I got out. Then using the reverse to pull through. Once through, I bent the wires criss-cross to keep in place, then once solid, quickly melt/move each wire straight out. Cut wire and done. Looks clean and solid hold, top-side nice and clean with no solder blead through.
I was surprised that the new resistors were much smaller than the old ones. Is that just new development in technology? The larger NTE resistors seemed to go up in wattage and Ohms.
This is good stuff to learn![]()
I replaced them with a 1/4 watt, 220 Ohm metal resistor with 2% tolerance (red band). What was in there was a 1/4 watt, (lower Ohm) metal resistro with 5% tolerance (gold band). Looking at Terra's photos, he used the same thing. They are the same size as the brown resistors just below them.
Amazing thing is the heat sinks on the transistors isn't even warm. I wish I understood why that is, and if that means that heat is going somewhere else? But I'm not going to worry about it, as it seems that it will work fine.
I just adjusted the bias and got it set exactly at 33.0 mV, but will test again to see if it varies or has changed. Then I'll button it all up and hook up tonight after work, and report back with the sonic difference, if I notice anything.
Are you sure it's a metal resistor? I believe mine was a regular carbon resistor from Radio Shack. If it's metal it will probably say so on the package.I replaced them with a 1/4 watt, 220 Ohm metal resistor with 2% tolerance (red band). What was in there was a 1/4 watt, (lower Ohm) metal resistro with 5% tolerance (gold band). Looking at Terra's photos, he used the same thing. They are the same size as the brown resistors just below them.
Funny, I would have thought the Concept would sound better since that has more wattage. But good to know and make me respect the HK even more.SUCCESS!
So the amp/tuner sound really nice. I can't tell if it's significant, but it's got nice imaging with the ADS L570's. I've decided those are a good match, as the ADS don't sound as good with the Concept 6.5.
Terra . . . I checked the speaker terminals and what was happening was this. With the DMM set to 200 mV, just like with the bias adjust, the reading would start around 1.0 - 3.5 and go down to 0.00 sometimes with a negative reading like -0.00, and sometimes waver around there, but mostly 0.00 - under 1.00 was the final reading. But what I noticed is that I was getting readings before I made contact on the speaker terminals, while I was moving the probes around the unit. Is that normal?
Wow, I didn't get an email reminder on this. I just saw, but where do I pick up my AK Audio Cubbie Badge????? :thmbsp:
Thanks Terra1 . . . I wouldn't have even tried this if not for you and others on this thread encouraging me, and especially for Sir.Byrd giving me the opportunity to have this cool amp!:thmbsp:
My readings were very close to 0.00, so even with fluctuation, were in what Echowars considered the best range to be in.
As far as my simple and not comprehensive test with the ADS speakers, I hadn't hooked them up to the Concept since fixing. The A150s sound really good with the Concept which I think is probably one of the better receivers of it's vintage, styling, power class and price/value. I know there are better, but for the 60w and under, I'm very content with it and while I know different receivers will have different sound characteristics, it's not like I find myself thinking I should replace it to find something "better" . . . but what I found interesting is the the ADS and H/K setup sound best on the jazz station. It's a combination (I think) of the type of music, source quality, strong reception, along with the circuitry of the H/K and the 2-way ADS speakers, that sound really good to my ears. I think it's the way they image, in the environment they are in. I should hook up the Kenwood KR-4070 again now that the ADS are fixed, to see the difference.
The Concept sounds significantly better than the H/K, in part because of the beefy guts and power, in comparison. But it has better detail, less 3D imaging, but really clean to my ears. What was interesting is that after listening to the ADS and H/K, I just assumed the ADS would sound even better with the Concept. But when going back and forth between the 3-way A150's and 2-way ADS, it got to a point where neither speaker was sounding "great". It's interesting how your ears can "demand" something different than what you're hearing . . . if that makes any sense. In short, if I could only keep the Concept or H/K, I would keep the Concept without a second thought. It's that good. I think the 3D imaging of the H/K overcomes the lack of power. I have to keep it in normal to just getting too loud for the sound quality to be at it's best. But even at too loud, it's surprisingly good for what it is.
In conclusion, despite some comments earlier in this thread that sounded like there was a general agreement that Harman/Kardon should have designed it's circuitry different in terms of heat dissipation, I would have to disagree—now with the 220 Ohm resistor upgrade.
I'm really curious to see what ecluser has been up to and look forward to his comments at some not-to-far-in-the-future posting???
Now try a hk 930.....................![]()
