Thanks!
I just finished cleaning up / lubing / adjusting a T60 I got last year ... and I have a sale pending on another T60 I got a couple years ago, which isn't in quite as good cosmetic condition. Had a T35 for a short time as well.
I might actually use this one as a test bed for doing the external power supply mod, before tacking the T60. Maybe dampen the platter and plinth and do the silicone in the tonearm bearings as well.
Sounds pretty darn good as it is though!
Thanks!
....the external power supply mod is only needed if you have a defective xformer with loose laminations. (Or if you use a Grado cartridge)
... Van Alstine's recommendation for applying 300k-500k silicone oil to the arm bearings is good advice....
On mine I also added clay (very carefully balanced) to the underside of the platter to increase its mass and deaden it.
IIRC, V-A doesn't 'do' the ITO arm bearing lube due to difficulties disassembling them.
... If you go through the V-A Audio Basics index, there's a later update where he figured out how to get into at least one of the ITO arm bearings for lubrication.
I've seen the reference to Grado carts with the T-series turntables in Van Alstine's Audio Basics - but they did it also to remove transformer hum.
For the silcone oil, it is 1000 centistoke (cSt) that is reported to be used. I'm not sure what '300k - 500k' is referrring to? .... Perhaps I have missed some references or corrections to what Audio Basics reported, but it seems to be that 300k - 500k, which equals (to me, at least) 300,000 - 500,000 wt silicone would stop the arm dead in it's tracks.
June 1985 issue - Lighter fluid to disolve the glue holding the cap on the vertical bearing and hypodermic needle to access the top horizontal bearing ... but I don't think you can get to the lower horizontal bearing (nor do I think one should try, based on warnings I've read on the complexity of the bearing).
I did that to my T55C and didn't like the sound. It killed the sound, flat & dull sounding.
Interesting tidbit I found in the Van Alstine Audio Basics. Apparently the alignment gauge supplied with the T-25 is wrong. See my post #31 in this thread re the T-25 guage:
http://www.audiokarma.org/forums/showthread.php?t=415327
Also some other notes and interesting discussion on alignment issues with the Harman Kardon tables in that thread.
And Frank Van Alstine provides a written description of the outboard power supply mod for the T-25 or T-30 in this thread here:
http://www.audiocircle.com/index.php?topic=95119.0
There's a gauge on VinylEngine for one of the higher T series turntables that's good for all of them. Of course, you can just use a Baerwald or Stevenson protractor ffrom that site instead.
.... the T-25 (which requires a single drop on each of the vertical bearings and one drop on the horizontal).
