A bit more info on gas tubes: http://www.tubecad.com/june2000/page3.html
Try it with what you ordered. May be fine.
If the gas tube pulses or does not light, add in parallel to the 6.8K resistor anything you've got in the neighborhood of 20K to 30K ohms (3 watt or larger). That will bring the total resistance down a bit and should address it, if it happens at all.
