P90
Member
I downloaded the file and unzipped it. I'm guessing the bold type are your readings. Yep, they're way off. Good call on NOT plugging it in.
Without knowing your technical level, and not wanting to insult you, all I can suggest at this point is to go through it again and carefully check that the parts and wiring are correct. Heathkit manuals are superb, but I've seen people get things one lug off, or one wire in the wrong place.
Having built and serviced well over 100 Heathkits, I've done it myself!
Hey Dr Jim!
I brought it up with a variac and dim bulb tester.
The Good: Nothing exploded or even got hot. The dim bulb remains nicely dim.
The Bad: No test signal reaches the outputs from any input, and front panel controls have no effect.
The Ugly: When I bring it up on the variac, as the voltage is increased or decreased, a sound like not unlike revving a motorcycle engine is heard from both channels. Not a Harley. More like a Honda. It is a constant sound, which increases in both frequency (not by much) and amplitude as the voltage is increased. The panel lights also get into the groove, getting dim then bright in time with the pulses.
Only brought it up to 120v once, and for a very short time.
I do have an old Tektronix 2213 that typically works on Fridays if I tap on it.
Also have a Multi-Function Tester - TC1 for testing transistors and diodes.
Thank for any help you can offer.
- Gene
