A Power Supply for the Heathkit Preamplifier Model WA-P2
The Heathkit WA-P2 is a monophonic vacuum tube preamplifier that was sold in kit form between early 1954 to late 1959. It was designed to complement the Heathkit power amplifiers of that time. The well written manual contains the complete specifications, description of controls, circuit description and assembly instructions. A downloadable manual can be found online. Original copies of the complete manual can often be purchased online from well-known auction websites.
Unlike most modern preamplifiers, the Heathkit WA-P2 does not have a built-in power supply. It was designed to tap its power, from the amplifier it was used with, through an eight-conductor cable terminating in an octal plug. This type of power connection was not uncommon in the early fifties. McIntosh, Dynaco and other manufacturers made preamplifiers that, in a similar fashion, relied on obtaining power from a power amplifier through an umbilical cord. All basic Heathkit amplifiers, of that era, had the proper socket for the power connection. Many other brands of amplifiers could also be adapted to provide the required power.
The easiest way to power a Heathkit WA-P2 preamplifier is to connect it to one of the Heathkit amplifiers, with the proper octal jack. Such a connection will provide the performance of the original design and deliver results that are satisfactory to many music listening enthusiasts.
When an original Heathkit amplifier is unavailable or if improved performance is desired, a standalone power supply is the answer. Finding a ready-built supply, with the right voltage and current capabilities, may not be easy. Oftentimes, one must modify or adapt an existing supply. Sometimes this is very easy and sometimes not so easy. Another option is to build a suitable supply from the ground up.
The power supply requirements are spelled out in the manual. From the Heathkit Preamplifier Model WA-P2 manual (pg. 6):
“POWER SUPPLY:
Requires power from external source, as follows:
6.3V AC at 1.0 amp.
300V DC at 10ma.”
The 6.3V AC supplies the filaments. The 300V DC supplies the B+. The Voltage Chart, on page 32 of the manual, shows the high voltage input specified at 320V DC, which is twenty volts greater than the page 6 requirements. Applying 320V to the first section of the filter capacitor could be a problem for early WA-P2 preamps because the early versions used an electrolytic capacitor with a 300V rating. Later Heathkit WA-P2 units were supplied with capacitors with a 350V rating. Be sure to check which capacitor is in your preamplifier if you intend to power it with a voltage greater than 300V. If you are “recapping”, go with a 350V, or greater voltage, capacitor for the first section. In my power supply designs, I set my target voltage at 320V to be consistent with the Voltage Chart.
Earlier this year, I set out to build a standalone power supply for my Heathkit WA-P2 preamplifier so that I could use it with a power amplifier that did not have a power supply socket. I constructed three power supply versions and tested several sub-circuits before I ended up with my final design. I am offering three design ideas in this thread. What power supply are you using? I would be interested in seeing what others are using for WA-P2 power supplies. Please post them if you have them.
System using a Heathkit WA-P2 with the WAP2PS01 power supply:
