I like the constant current source idea. Since each preamp will draw 10mA or slightly less, I would use 20mA load if you are building for two preamps.... Might also consider changing the load from a resistor to a constant current type. Won't matter all that much really but its a bit more like what it will actually be dealing with.
I would also recommend adding a pair of zener diodes to the output to limit the DC voltage at startup before the tubes warm up. e.g. 1N5385 + 1N5385 in series.
