The Sanyo STK3042 (NTE1338) is similar to the STK3062 (NTE1339) or STK3082 (NTE1339).
The STK3042 is a dual driver usually used with STK1050 or STK1060 output chips. The STK3062 or STK3082 were used with STK1060 or STK1070 output chips.
The STK3062 or STK3082 are the same as the 3042, but have higher voltage ratings. The pin out's for the 3062 and 3082 are the same as for the 3042.
http://audiolabga.com/pdf/STK3042.pdf
You can order from Sound & Light Electronics, they ship internationally.
http://www.slelectronics.net/STK0_STK5/semicon.htm?PHPSESSID=422b81436fe911073073d2269fc8ebd2
You can order the STK3082 from
http://www.electronicsic.com/sem-stk.htm From ElectronicsIC the STK3082 has a higher rating and costs less than the other two.
And here from Mouser Electronics
http://www.mouser.com/search/refine.aspx?Ntt=STK3042
http://www.mouser.com/search/Refine.aspx?Ne=1447464+254016&Ntt=*STK3082*&Msb=0&Mkw=STK3082&N=1323038
Mouser shows the NTE1339 (equivilent to the STK3082) is in stock now.
The STK3042 (or other) dual driver gets quite hot. It looks like you have room to do what I did. I cut a piece of aluminum sheet the same width and twice as high as the STK driver. I applied heat sink grease to the back of the STK driver, and attached the aluminum with a nylon Ty-Wrap. This more than doubled the amount of radiating area and the chip is cooler.
