desertrat748
If the issue is that pesky running wild in reverse problem then he needs to replace the speed control circuit board (same circuit as speed switch and power supply) not the board by the tonearm or the motor board.
Agree with you on replacing the speed control circuit, but it's not on that little board with the 33/45 selector switch and fine speed var resistor. The only parts on that board are converting the transformer voltage from AC to DC via a bridge rectifier.
I’m suggesting that he jump out the speed selector switch to see if that is it. He said in his first original post, that the switches were all gummed up with like nicotine or something. If that is true it will mess those switches up. I’ve had the same problem. It would save them a ton of money if he would swap out the switch or the control board.
My 2 cents. If It is the switch itself that is gummed up and causing the motor/board to get a bad signal it will not matter if he replaces the speed controller board, because the switch could be the problem.
