Sounds like a good plan. If you make your own coils you might as well make the entire crossover.
It would probably be more economical in the end. The one crossover from my friend I'll get for what he paid for it (not much, I'll message you) but we would still have to find a second one and then there is shipping. Best thing to do is look at what prices you can find locally for the caps and resistors and coil wire and then compare and decide. My guess is that finding a second crossover will be in the €25 to €40 range. Shipping from here to you would probably be another €15+.
I haven't the slightest idea what brands are available where you are. Many of the economical brands that are often used by others in the forums aren't available over here in Germany. I've been using Mundorf MOX resistors, Mundorf elecrrolytics and Jantzen Foil caps and coils. The coils for the woofers were some of the the most expensive parts when I made new crossovers for my Speakerlab 7's so you would save a lot of money there if you roll your own.
Note that Canton used MKT caps for the tweters (C4). If at all economical for you I highly recommend using MKT or even better MKP. Using elcos on the tweeters will degrade the sound quality.
Cheers,
James
Cheers,
James
