Help With 2SA906 Replacement in Differential Amp
rd48sec
Sansui AU-317 has a noisy left channel. Traced it down to TR05 in the Control Amp. Is a good replacement for the 2SA906 a KSA992? Should I replace TR03 also because of being a differential amp?
If look more carefully, you will see it is the packaging options, loose vs on paper tape for auto insertion, so it is lead formed, both the same part electrically.
BU = bulk
ATA = ammo pack
for you order the bulk version unless you want lead formed, 3 leads side by side 0.1" apart
Thanks, rcs16!
I'm about to order these too for another unit here (later I'll open a thread) which has noisy TR's.
If may I ask one more info, C09 and C10 (in the schem. above) must be kept same capacitance value, right? Thanks again.
