B527 - 110V, 800mA, 10W, B=100 min
D357 - 110V, 800mA, 10W, B=100 min
These are TO-220 devices. The 2N devices listed above are a bit shy on voltage, and also look to be lacking a bit of gain. Additionally, they are TO-126 devices, which may or may not be adequate, and probably have a different pinout as well. If the original TO-220's are heatsink mounted, then a different pinout is going to make them difficult/impossible to use.
How about the Toshiba 2SA1837 and 2SC4793? Mouser has both, and they should have the same pinout as your originals (this is something you must check on your own).
These are fully encapsulated devices, so if Sansui is using the tab as a live conductor (as they sometimes do), you won't be able to use them.
