If it has a phono input, you should be fine. Be sure to hook up the ground wire (if the TT has one) to the ground screw on the receiver too.
Depends on the model - which Sherwood model # is it?
I checked your Teac receiver. It does have phono inputs, so you’ll be fine.
I have an S-7250, I believe that is the model number.
What does that mean? I think the Sherwood has 20w Per channel, and I think the TT had 75 per? Means it is four times as powerful?TT's do not have power! Sorry to holler.
Thanks for the info folks. Am I correct in my understanding that the TT that I just purchased has more power than the Sherwood?
I have the new receiver hooked up and it is working. However two things I can’t figure out. When I select speakers a or b it plays out one side or the other. But when I select both I get no sounds. Also I have to turn the volume up very high to get the record to come in on a good volume. I have attached some photos. Can someone help?You are using both the A and B speaker terminals incorrectly. You should be using the top row only!!! Make sure you use the correct positive and negative terminals for each speaker.View attachment 1179402 View attachment 1179403 View attachment 1179404 I have the new receiver hooked up and it is working. However two things I can’t figure out. When I select speakers a or b it plays out one side or the other. But when I select both I get no sounds. Also I have to turn the volume up very high to get the record to come in on a good volume. I have attached some photos. Can someone help?
Whoa! That made a huge difference!!!!!! Let me try the TT now.You are using both the A and B speaker terminals incorrectly. You should be using the top row only!!!
