Help with new receiver
I would look at the headshells. If they look essentially the same (i.e. the angles from attachment point to cartridge orientation aren’t different), then you’re probably okay.
But long term, you may want to just switch the good cartridge to the proper headshell so everything is matched.
If you plan to keep the 2nd TT, you can pick up a cheaper cartridge and mount it on the second headshell.
Glad it all worked out. Time to buy some records!
