Here It Is: The All Singing All Dancing HTMCPS
I just saw this. I have the resister calculator provided by Hypnotised for this. I will post the values in few hours.
Regards
Sachin
i have the HTMCPS currently configured for an AT33PTG/II, which is .4mV and 12R. what would a good resistor combo be for a Benz Micro Ace Medium (.8mV and 24R)?
You can use 10R or 50R for R1 and R9 and 120R for R2, R10
Regards
Sachin
Regards
Sachin
having the system dismantled briefly for painting, i finally pried the AT33PTG out of the Linn and installed/aligned the Benz Micro Glider SM (for some reason, it was a bit more particular to get it right visually than the AT). i then changed out the resistors on the HTMCPS: nice Dale 120R for the 220R in R2/R10 and a parallel combo of 47.5R for the 10R in R1/R9. i also took the opportunity to roll some different tubes in the pre/amp, so any individual change is a bit hard to pin down at this point.
nonetheless, i am really liking what i'm hearing, and the overall result is better with the Benz. surface noise is a bit more muted, the background hiss from the preamp is lower since gain is set lower, and the cartridge just sounds bigger and more relaxed. if i ever get motivated enough to do so, i may try lowering the 47.5R "loading" resistor to something like 34R to see what change it makes. initially, i thought that upper strings seemed a bit muted compared to the cello and bass...
