My apologies in advance as I'm a novice at this yet would love to learn, so I appreciate any feedback
I have an early-model 299D that powers up and tubes light up, but no sound is coming out of any inputs (also checked cables and speaker connections). I'd appreciate any troubleshooting tips to identify where the breakdown is occurring.
The selenium rectifier was replaced with bridge rectifier GBU6K-BPMS-ND 800V 6A. Since I'm not getting any sound at all, I'm wondering if this ties back to the power section or to the DC balance?
Here are the different measurements I took at 114V --
Rectifier 5AR4
I appreciate anyone's help with this as I tried to measure what I could at once. Thanks.
Rectifier 5AR4
- Pin 4: 378VAC from PT
- Pin 6: 379VAC from PT
- Pin 8: 515VDC -- This seems to be too high. Have used two other rectifier tubes with similar results
- R211 20 ohm 10W: 515V --> not sure why this is not stepping voltage down since it's a new wire round resistor
- 30/500 cap to OT: 515V
- ~ : - 29.7V
- ~ : - 29.5V
- + : to ground 2.57VAC
- - : - 60.5V
- R216 10k: - 51.1V
- C212 to DC Bias: - 51.0V
- Pin 3: 515V
- Pin 4: 42.0V --> should be 410V?
- Pin 5: .005VAC (0 DC)
- Pin 6: - 21.1V
- Pin 8: 42.0V --> should be 410V?
- Pin 3: 515V
- Pin 4: 42.0V
- Pin 6: - 21.6V
- Pin 8: 42.0V
- Pin 3: 515V
- Pin 4: 41.9V --> should be 410V?
- Pin 6: - 26.9V
- Pin 8: 41.9V --> should be 410V?
- Pin 3: 515V
- Pin 4: 42.1V --> should be 410V?
- Pin 6: - 26.7V
- Pin 8: 42.1V --> should be 410V?
- Pin 1: 18.59V --> should be 225V?
- Pin 2: - .572V
- Pin 3: 7.85V --> should be 45V?
- Pin 6: 8.80V --> should be 65V?
- Pin 7: .118V --> should be 1.3V?
- Pin 8: 9.10V --> should be 75V?
- Pin 9: 8.79V --> should be 65V?
- Pin 1: 18.58V --> should this be 225V?
- Pin 2: - .464V
- Pin 3: 8.33V --> should this be 45V?
- Pin 6: 9.22V --> should this be 65V?
- Pin 7: .105V --> should be 1.3V?
- Pin 8: 9.43V --> should be 75V?
- Pin 9: 9.22V --> should be 65V?
- Pin 1: 22.6V --> should be 170V?
- Pin 2: - .451V --> looks like this should be 0V. Is this level of DC okay?
- Pin 3: 0.22V --> should be 1.25V?
- Pin 6: 22.6V --> should be 170V?
- Pin 7: - .355V --> looks like should be 0V
- Pin 8: .024V --> should be 1.25V?
- Pin 1: 22.8V --> should be 170V?
- Pin 2: - .357V --> looks like this should be 0V
- Pin 3: 0.21V --> should be 1.25V?
- Pin 6: 23.0V --> should be 170V?
- Pin 7: - .408V --> looks like this should be 0V
- Pin 8: .018V -> should be 1.25V?
