carlman14
Member
Hello all! I recently picked up an HH Scott LK-72 with the original manual. It was untested due to the previous owner never getting around to restoring it. From what I've seen, this looks like it's the earliest version of this amp (7199 tubes, no balance pots, two 0.05 uF coupling caps in parallel). This is my first restoration of anything like this, and I'm super excited. I'm creating this thread to log the restoration of this amp, and to ask lots of questions! Here's some info on what I have:
Current state:
Examples of the tiny caps that are everywhere:
Current state:
- Had to replace the fuse and busted fuse holder. After that, the amp turned on and I was able to get sound to play through both channels.
- Front power light works.
- Bass, treble, and channel balance pots work.
- There was one joint that was completely unsoldered. Fixed that asap!
- State of turntable and tape deck (and associated pots upfront) is unknown. I'm mostly interested in the speaker outs.
- New tubes (Especially the 12AX7's. They're barely glowing)
- Replace capacitors. Replace: Ceracaps (orange drop), The coupling caps (two 0.05 uF disc caps in parallel), Top-mounted large caps (https://hayseedhamfest.com/collections/scott/products/h-h-scott-lk-72-re-cap-kit-4-cans)
- Replace power transformer (Maybe. I heard it's smart to replace the PT in the early versions of this amp with a 299C transformer from heyboer) (https://www.heyboertransformers.com/)
- Replace bridge rectifier
- Rewire 7199 sockets to support 6U8A (Identical tube with different pinout. Much cheaper and more plentiful than the 7199). Or buy adapters.
- Figure out balancing (and potentially add balance pots)
- 60 hz hum in both channels
- One channel is noticeably worse/weak sounding (bad tubes maybe?)
- Very scratchy volume pot
- Do I need to replace the disc caps?
- There's tons of tiny caps all over the place (At least I think they're caps). Should I replace those too? I took a couple pics to show these.
- Is this the version of this amp that needs a new power transformer from heyboer (299C I think)?
- What SS rectifier do I need? Any specs I should look out for?
- All the caps are marked "MFD" after the value. Is this equivalent to micro farads (uF)? Or is it milli-Farads?
- How would I add balance pots to this version of this amp? That would be very convenient to have.
- Is it possible to add bias pots for the output tubes to this version of this amp?
- Is there anything else that should be done as part of this restoration?
