I put in a 33 ohm-5w resistor in mine as recommended. I also keep the amp plugged into my Variac set at 117v. Probably not necessary, just my anal brain thinks it’s safer.Another question for y'all: Is a 2W enough for the first resistor after the bridge rectifier? I got the bridge rectifier and the 75/75/75/75 can cap replaced today, and am trying out different first resistors to get -45V. However, that first resistor is getting extremely hot, even after a minute or two of operation. It's so hot I can't touch it. Is that ok? Or should I get a resistor with a higher watt rating?
LK-72 is about the best one that Scott had (other than the LK-150, 272 and 296 which are scarce and expensive!). For the most part, from the beginning, they were the more powerful Stereo Integrated amplifiers utilizing the 7591 outputs.
Cant say for sure what sounds better but i personally hold the 280 mono amps to be the totl for HH scott.
That being said, my 299d isn't for sale...
I am sure that you will be pleased.
As already said by someone, find some place to test your tubes. The 12AX7’s are probably still healthy but the 7591’s, even if looking good visually, could be on their last leg (or not...).
It's been said to me many times that the absolute best test for tubes is the device that your using them in!. Once you have the caps replaced and the fixed bias supply working, you'll be able to tell pretty quickly if your output tubes are working.
It’s ok but it’s fine to know, even with a basic emission tester, when an output tube is completely dead or shorted...It's been said to me many times that the absolute best test for tubes is the device that your using them in!
This is why I keep mine plugged into my Variac, set at 117v.What is your wall voltage? The unit was designed in an era where the expected voltage was 117 or so volts. I used a couple of thermistors in series to drop mine a couple of volts to get the voltages down. You would then likely need to adjust the bias string resistor also if you go that route. Those voltages aren’t dangerously high though, but it is a good idea to get them closer to the schematic values.
Good job!
Fabulous! You’re going to love the lush, rich sound this amp produces. Lots of low end grunt as well.Aaaaaand Done! I'm going to triple check everything is wired up correctly, then turn it on and check voltages. Kinda nervous to turn it on...
Good job!
Those voltages all look great. The plates and screens are bit high, but you have 3v extra bias at the grids to compensate. Do you have a way to measure plate/cathode current?
Thats about the last meaningful check to make before you play some music.
My guess, is that you will find the bias current to be within spec, and you are about to find out that an HH Scott can sound really good!
My wall voltage is 123.5V... so definitely higher than the average back then... and even high for the average now. I have some CL-80's on hand. How would I wire those up?
You wire them in series with the hot line before the power transformer.
