carlman14
Member
Wiggle tubes, the 9-pin tubes. If anything changes, please clean the tube sockets. That had been the most troublesome issue on the Scott amplifiers that I have brought back to life. Easy to fix.
I wiggled them all and cleaned out the sockets with some deox-it. The channel imbalance is a little bit better. I'll clean them out some more and see if that helps.
That buzz is a different problem though. Here are the symptoms: It sounds like it's 60 hz. Turning up and down the volume pot has no effect on it. The buzz starts 15-20 seconds after turning the amp on (basically after the slow start of the 5AR4 warms up and starts rectifying AC). Turning the channel balance pot all the way to the left channel causes the buzz to stop in the right channel. Similarly, turning the channel balance pot all the way to the right channel causes the buzz to stop in the left channel. All of the other front panel controls (treble, bass, input selector, phono EQ, etc) has no effect on the buzz.
Here's what I've tried so far:
- different input, output, phase inverter, and rectifier tubes.
- checked all solder joints and made sure nothing is shorted.
- wiggled tubes in their sockets and cleaned out the sockets.
- removed the AC wiring from the front panel switch (there were reports of AC hum bleeding into the sound from this un-shielded wire).
Here's a link to the sound if that helps anyone (turn the volume way up to hear it!): https://drive.google.com/drive/folders/1DCOg25xAYlfRVj39IkjTesuiaBps4ai7?usp=sharing
Honestly, I can live with the channel imbalance for now since I can balance them out with the channel balance pot... but this buzz is really annoying and I'd like to get it fixed. Anyone have any ideas?
