You guy's think I did good on it, I was going to send it back I have to pay return shipping, now after seeing what you guy's thinkEasily worth what you paid, and easy enough to reverse engineer if you think it's not right.
Did you even try it to see if it worked okay?
Clean pots with Faderlube and just use it for a while. Don't use DeOxit D5, don't use WD-40, don't use alcohol. Use Faderlube.The seller said it work, just noisy pot's which I could clean mmmmm I'm thinking now.
Can you explain why Faderlube and not D5? Just want to understand.Clean pots with Faderlube and just use it for a while. Don't use DeOxit D5, don't use WD-40, don't use alcohol. Use Faderlube.
How's this look, it looks a lot better cleaner, I added 10uf 50volts caps like in the schematic and
added wires to the outputs replace the 220 ceramic with Wima 220 caps still have to wire the phono
section have to figure out how that's done. Doesn't anyone have any pictures of the DH-101?
View attachment 2524064 View attachment 2524066
Crosstalk between stages thru the power rails.I never understood bypass caps. the math on parallel caps is easy; C1+C2+C3=Ctotal. You are changing the value of the equivalent capacitor. What do they think they are improving?
To avoid dissolving the resistance track and washing it out. Faderlube is formulated specifically NOT to do that.Can you explain why Faderlube and not D5? Just want to understand.
