hooking up 901's to new yamaha rx a2020
marauder25
how can you hook up bose 901's to a yamaha rx a2020 home system
had them hooked up to a yamaha rx v3000 but its dying
no main in and out on new receiver
Not a clue. Just looked at a pic online and thats way too much stuff on the back of that thing. I'm assuming that it has no tape 2 in / out and a monitor selection?
I'm thiking not.
Well, you CAN hook up the speakers, but connecting the equalizer is where the problem arises.
Scan your owner's manual for a tape monitor LOOP button. Not just tape in and tape out jacks. There's a big difference.
To insert an equalizer or similar in-line processing device, one needs to insert it somewhere in the circuit path. You must break the circuit, send the signal out to the device, and then return it into the circuit exactly where it left it.
This is generally done with a tape monitor loop circuit, which is activated by a “Tape Monitor” switch/button located on the front panel. This is more than just a tape input and output jack.
I have yet seen an AVR with a “Tape Monitor” switch. Your only hope then is if your AVR has preamp out jacks and access to a power amp in, whether it be jacks in the receiver, or an external power amp.
Please note that some units, like my NAD 1600 have an “External Processor Loop (EPL) button that does exactly the same thing but, then again, that's astareo analog piece. ...not a digital AVR.
The next few paragraphs deal with using a tape monitor circuit on a stereo receiver. The one possibility for AVR’s are covered a few paragraphs down.
In the good old days of analog two-channel stereo, adding an equalizer was as simple as pie. You simply located the tape monitor output on the back panel, ran an interconnect from there to the eq’s input, and then ran another interconnect from the eq’s output back to the tape monitor’s input on the receiver. You turn on the eq, push the “Tape Monitor” button on the receiver in, and, viola! Your eq is now in the circuit!
Or, to put in a more visual sense
• Amplifier/receiver tape output to equalizer input
• Equalizer output to Amplifier/receiver tape input
• Press “Tape Monitor” button on the Amplifier/receiver and you’re in business/
Likewise, to take the eq out of the circuit, you just pushed the “Tape Monitor” switch again to restore the internal signal path.
Essentially, what the “tape monitor” button does can be described in two steps.
1) When the “tape monitor” button is in its “out” position, the signal is fed internally from the “tape out” jacks to the “tape in” jacks.
2) When you push it in, that out/in connection severed, the signal goes out the “tape monitor out” jacks, through the external device, and then back into the “tape monitor in” jacks.
This is why pushing the “tape monitor” button in when nothing is connected to the “tape monitor” in and out jacks, the signal will disappear. It’s going out but never returning.
Now, if one is talking about one of the current AVR's, simply having tape out and tape in jacks on the back panel does not guarantee that it will create the needed "monitor loop" configuration. Again, I have yet seen an AVR with a tape monitor switch.
While many AVR’s might have “tape out” jacks on the back to allow you to send an analog two-channel signal out to an external device, it’s generally a one-way trip.
Likewise, they might have a “tape input” on the back to allow you to play tapes through your system, but odds are it must be selected via the input selector, which makes it worthless for the purpose of inserting an eq into the circuit.
The key is to scour the front panel for a "tape loop" or "tape monitor" button. Without that, these two sets of jacks simply allow a signal to be sent out to a tape deck but that tape deck's input must be selected as another input, not the out/in loop, as many have discovered.
So, if you do indeed have the needed "tape monitor loop" then you're good to go but be aware that it will only affect two channels, most likely the front two.
One way to verify you do have what's needed is to take one stereo interconnect and connect the tape output to the tape input in question. Switch the receiver to FM, CD or some other source besides tape, and press the tape monitor switch. It should sound exactly the same. If you lose the signal, there's a problem. Likewise, not being able to find the "tape monitor" button/switch on the front panel is a problem also.
But, not all hope is lost. In some cases, you can use an eq between the preamp stage and power amp, assuming the receiver offers these I/O options. Some receivers have outputs but no power inputs. In that case, you'll need to feed an external power amp. There’s a downside here in that you might pick up a bit more moise than you would if you had used the tape monitor loop, but sometimes you have no choice.
strange that Bose has not addressed this problem, all the new AVRs have no provision for inserting a processor like the Bose eq, from my recent inspection of receivers at BB and others. the units are designed to use their own 'DSP'.
may be time for Bose to jump back in with their own AVR with enough watts to handle the boost. (or maybe Bose is going to let the 901 lapse into obsolescence?)
It would be good for our OP to post a picture of the rear of this rather expensive AV receiver. Yamaha wants you to sign up for their marketing mess before they will allow you to download the owner's manual - that's not interesting for someone who's trying to help.
Ok, I went through the Yamaha gauntlet and find that there are, indeed, Pre-Output jacks (see p33) but there are no corresponding inputs in order to use the internal power amps. This means there's a way to use the 901 EQ but depending on what other things you want to hook up, it will likely be limiting to all the do-dad features you have on this Yamaha.
To use the 901s and the EQ, you'll need an extra amp. Connect the 901 EQ to the Pre-outputs for the front L/R. Then connect the EQ outputs to the separate power amp, which then drives the 901s. When listening to music, select the simplest stereo mode you can get on the receiver to route 2-channel to the L/R of the 901s.
I do not see a real Audio Loop available on this receiver. Clearly it is designed for the home theater crowd - not the old-school audio crowd like me!
Cheers,
David
Googled, it, clicked "images" and found many. Just clicked it to enlarge it and could read everything clearly.
Cheers,
David
i like this idea - hate to spend more money
If you just want to listen to and external source, such as a cd player. Hook the external source into the EQ, then hook the EQ into the receiver. Yes? Disadvantage: you would have to keep swapping the external sources into the EQ unless you use a audio selector between the EQ and external source.
