HORN ALMIGHTY my ultimate project
Helmuth
HORN ALMIGHTY my ultimate hornspeaker project
Hello musik lovers,
I sold my latest project the fatboy. So I can try new designs.
Fatboy a 160liter bandpass.
And a bass reflex project.
and a other little one.
I am torn between a new openbaffle project or a super Horn project called "HORN ALMIGHTY".
After my first Horn successes 10 years ago I decided to go for the horn because I am also building a 10W triode amplifier. I had good experiences with them real drums super impulse behaviour.
Here a picture Left the last stage titanium drivers backloadedhorn active two way. Van den Hul wiring. And a own designed preamp that was straight up to 1Mhz.
Middle first stage with a 10inch right the test unit.
:ntwrthy: horn almighty :ntwrthy:
Result simulation 110-105dB 1Wmtr -3dB 35Hz!! :banana:
The frontside
Formula to calculate efficiency at 1Watt.
Sensitivity in dB = 112 + 10 log (efficiency)
Efficiency = (10^(Sensitivity in dB – 112)/10 ) *100%
Efficiency of your loudspeaker at 1 watt 1meter
85dB 1Wmtr = 0,19%
90dB 1Wmtr = 0,63%
95dB 1Wmtr= 2%
100dB 1Wmtr= 6,3%
105dB 1Wmtr= 20%
110dB 1Wmtr= 63%
Where does the 112 dB come from? The 0 dB reference level for sound is 10−12 watts.
1 acoustical watt means 120 dBSPL.
The standard measurement for loudspeakers is done with an infinite baffle sounding in a half room with a distance of r = 1 m.
The resultant factor 2 π × r2 (area of a half sphere) equals −8 dB. Therefore we get for an efficiency of 1 = 100 % a sensitivity of 120 − 8 = 112 dB.
Hi music lovers,
It is bin quit here for a while but I was still working on the project. I entered the test phase.
It looks good till now good efficiency and response down to 40Hz :yes:
Here a picture.
Do like what you see?
These speakers have a high WAFactor because the average women don not see a loudspeaker, because they are to big to be loudspeakers. :naughty:
