Hey folks,
I recently had an interesting experience and wanted to share this with you all to try and make sense of things and perhaps better understand how amplifier matching works.
I currently use a pair of Sansui SP-X9000 and Acoustic Research M3 as my main listening speakers. I usually switch between them depending on mood but generally prefer the bigger/fuller sound of the Sansui. I also have a pair of Acoustic Research M1 speakers stored away.
I use a Marantz PM300 to power the speakers but was on the lookout for something with a little bit more grunt. Eventually I picked up a Teac A-H500, which has a little bit more power and is apparently really well designed/built (based on reviews).
Excited I plugged the Sansui into the Teac amp and I was utterly disappointed. The sound seemed dull and somehow incomplete compared to the Marantz. Confused and disappointed I plugged the AR M3 into the Teac and was surprised to hear these speakers sing. I spent several hours switching between the speakers with no change in results even after messing with EQ and speaker positioning. Lastly, I tested the Teac with my AR M1 speakers and had similar results as the AR M3, they paired well and the sound was full, rich and dynamic.
From my experience I can only assume that the Teac is simply not a good match for my Sansui speakers but somehow the Marantz is? I've read another thread on here about amplifier speaker matching and it seemed like trial and error is the only way? What would be a good match for the Sansui in this case? Do I need amplifiers from a similar era as the speakers for them to sing and sound good? Or could I get good results with a modern amp on a vintage pair of speakers like my Sansuis? Gosh, even if a pairing sounds great, how do I know if there is a better match out there? (this last one is obviously a rhetorical question haha)
Some additional info on the gear I used:
- Sansui SP-X9000, 4 way, 6 driver, ported, 25Hz to 23kHz, Sensitivity: 98dB, 8 Ohms, year 1978
- Acoustic Research M3, 3 way, 3 driver, sealed, 53Hz to 20kHz, Sensitivity: 90dB, 4-8 ohms, year 1991
- Acoustic Research M1, 2 way, 2 driver, sealed, 65Hz to 20kHz, Sensitivity: 88dB, 4-8 ohms, year 1991
- Marantz PM300, 30 watts @ 8 ohms, 15Hz to 50kHz, THD 0.04% year 1979
- Teac A-H500, 50 watts @ 8 ohms, 5Hz to 80kHz, THD 0.03%, year 1997
