How does a tube amp work?
That would be great. I had a friend over and he said he would take a look at it. I think Fear I will never see it again.
I would have preferred Micanol five pins for my amp rebuild because, you guessed it, the original Micanols had bad contacts. No amount of cleaning or reshaping worked over the long term. Because I could not find new Micanol five pin sockets and being a bit gun shy, I did not want to use even NOS and resorted to ceramic with, at least since last November, no problems with these amps, which I use every day.
(It would have been a lot easier to use the Micanols. Let's just say that my trusty Greenlee punch was indispensable .)
I'm thinking about cathode bypassing caps for my amp. I'm not sure what the voltage is. I can measure it easily but it is across the house and I'm lazy. This idea just came to me this afternoon.
I appreciate the help guys!
You build a circuit to turn AC into DC where the components will work. Then you start running current in the active devices, tubes in this instance. The parts around the active device, tube, are there to make the active device work. Then there are certain components to control the amount of current running in the active device, tube.
Compare current, electrons flowing like comparing water flowing with valves determining how the water is divided, increased or decreased. With water you have a valve to determine where and how much water flows where. In electronics we use active devices, tubes, transistors to control DC current. Europeans call tubes valves for a reason. That is what they are.
Country boy explanation.
