How does a tube amp work?
That headphone amp with the 6922 (industrial 6DJ8), the tube is there so it has a tube for people to buy. Could be a voltage amplifier on the front end, or a cathode follower on the tail end to lower the output impedance. There's no real reason for it to be there.
A few sources...
Crowhurst books (all good)
RDH4 (Radiotron Designers Handbook)... very long, 1,498 pages.
Morgan Jones "Valve Amplifiers"... ( "Indeed to goodness!")
Marcus & Levy "Elements of Radio Servicing" (Not Hi-Fi)
GEC, England "Audio Frequency Amplifiers" (Good designs)
Mullard, UK "Tube Circuits for Audio" (ditto)
...plus an infinity of Internet sources...
Hope this helps,
Cheers,
Roger
A few tube stages are required to make enough output for the speakers.
"A few" generally means 3, but many SE amps have only two stages per channel, including some of the popular Magnavox models, which use one section of a 6EU7 or 12AX7 and one 6BQ5 per channel. The so-called "Spud" amp designs, which only have one tube per channel use tubes, such as the 6EM7, with two sections in each tube.
But as I unexpectedly learned, it's possible for a single tube section to drive speakers to quite reasonable levels.
A couple of years ago I modded a little Voice of Music SE 6BQ5 amp. The amp originally had an external preamp with a normal NFB loop from the amp to the preamp section through an unbilical. But I only had the amp section. I could have connected the 6BQ5 in triode without any NFB but I wanted to get as much power output as possible so I ended up using local "cathode" NFB so I could run it in pentode. The plan was to use it with a variety of preamps.
While testing it with a few different preamps, I decided to try running a signal straight into the amp with no external active preamp. Just a line level signal and one 6BQ5 per channel. Surprisingly, it worked quite well.
Sure, it produces more power with a preamp, but the sound was not weak at all. It played loud enough for me to listen while working on the computer, even though the amp and speakers were in an adjacent room. Speakers weren't ultra efficient either, probably ~93dB. It would work even better as a desktop amp with a near field speaker setup.
Of course the 6BQ5 is one of the easiest tubes to drive, which is a key factor. I've seen other amps that only use a single tube section but they're designed for headphone use where very little power output is needed.
But it turns out that a single tube section can drive speakers if you use the right tube.
I didn't want to start a new thread but I thought I would ask here.
I'm good with cathode, plate and multiple grid arrangement but a friend is having problems with a 6550. The indication of pin 8 confuses me. It doesn't seem to be a normal grid. Do you know what it is?
Hi Grainger49, Pin #8 on a 6550 is the cathode and grid #3 tied together on that single pin. Here is the 6550 pinout illustrating the cathode / grid #3 connection to pin #8 :thumbsup:
PS, here is a link listing the various vacuum tube components and their function.
Strictly speaking, the 6550 is a beam tetrode rather than a pentode, and doesn't have an actual G3 suppressor grid. The beam physics of the tube uses the 3rd element "directors" to create an effective virtual suppressor zone instead with the directors held at cathode potential.
The interesting thing, to me, is that like in a transistor amp you set up a current through the transistor (tube) and then modulate that current with the base (grid) voltage.
There is a whole lot more there but it is the same general idea.
Sept. 7, 2021 EDIT: PDF of this complete thread attached below.
CAUTION - TUBE AMPS CAN USE 500+ VOLTS DC POWER WHICH CAN KILL YOU. BE CAREFUL, ASK QUESTIONS FIRST.
Useful links for tube and tube amp information are located here.
Explanation of how a tube amp works is continued here and here.
What are the parts used in a simple triode (three part) vacuum tube?
attachment.php
Anode – the piece of metal in a tube, also called the Plate, which is positively charged (B+ DC voltage) and to which the negatively charged electrons flow. The electrons flow out of the tube via the anode (plate) to generate an electric current. In a small signal (preamp) tube, the anode current is fed to the control grid of the power tube. In a power tube, the anode current is fed to the output transformer input winding.
Grid – also called the control grid. It is placed between the cathode and anode. The grid uses a negative bias voltage. The AC signal from your source (e.g., CD player, turntable, tuner) is applied to the grid. The grid acts like a valve inside the tube that controls the flow of electrons from the cathode to the anode. This is why vacuum tubes are also sometimes call Valves, or thermionic valves.
While we are using the water hose analogy to understand electricity, think of electrical voltage as being the pressure inside the water hose (wire), electrical current being the flow rate of water through the hose (wire) and a ball valve or nozzle on the end of the hose being an electrical component, like a resistor or rheostat in the electrical circuit, that controls the flow rate of the water through the hose (wire or circuit).
If a tube didn't have a control grid, the signal leaving the tube would be at the maximum all the time. The control grid regulates the flow of electrons from the cathode to the anode. Higher electron flow equals more amplification.
Cathode – the piece of metal in a tube that surrounds the heater, but does not touch it (an indirectly heated cathode), or is located nearest the heater. The cathode emits electrons when heated and DC power (B+ voltage) is applied. These electrons generate a current as they flow from the cathode to the anode.
Heater – the filament (piece of wire usually wrapped around a rod) that heats the cathode so the cathode can emit a cloud of electrons. Electrons are negatively charged. The heater is what you see glowing inside a vacuum tube you amp is turned on. The heater is also of course what causes the tube to be hot to the touch. Heaters typically use AC power (but can use DC power), 6.3 volts for 6DJ8 and similar tubes, 12.6 volts for 12AX7 and similar tubes.
Getter – usually a halo shaped piece of metal wire near the top of the tube, but it can also be on the side or bottom. Other shapes are also used: squares, “D” shaped, windmill, dishes, etc. The getter is coated with a highly volatile powder before being installed in the glass envelope. The getter has no effect on how a tube operates in a tube amp. After it is flashed (see Getter Flash below), it serves no purpose.
Getter flash – after the tube is built, all the air removed and sealed to create a stable vacuum in the tube, the getter is flashed by heating it and the volatile powder explodes and created the getter flash. Getter flash appears as a silvery mirror-like coating on the inside wall of the glass envelope near the getter wire. Getter flash turns powdery white or light brown as a tube ages. This is typically caused by a slight loss of vacuum in the tube and the air that leaks in reacting with the getter flash. Loss of getter flash can indicate that a tube is going bad. If the getter flash is 100% powdery white, the tube is probably bad.
Glass envelope – a glass bottle (or sometimes metal) is used so that the air inside the tube can be evacuated to create a vacuum inside the tube. A vacuum is required to keep the components inside the tube from burning up rapidly.
Base and pins – the base, usually plastic, gives the bottom of the tube and pins mechanical strength and reduces the potential that the tube will be damaged during installation and removal. Most small signal tubes(e.g., 12AX7s, 12AU7s, etc.) and some power tubes (e.g., 7868s) don’t have a plastic base. The pins are the electrical connection between the components inside the glass envelope and the tube sockets in the amp, preamp or tuner section of the tube amp.
If you want to know what each pin of any tube does, check out the Duncanamps.com searchable database: http://tdsl.duncanamps.com/tubesearch.php
attachment.php
Types of vacuum tubes?
Tubes like the 12AX7, 12AU7 and 6DJ8, all commonly used in preamp sections of a tube receiver or integrated amp, are all dual triode tubes. This means they are actually two tubes in one glass envelope. Preamp tubes amplify the signal only a little bit in comparison to the amplification achieved with power tubes.
There are many other kinds of vacuum tubes. For example, a pentode power tube like the EL84/6BQ5/7189 contains all three components described above (cathode, anode, control grid), but adds two more grids (screen grid and compressor grid).
What does the Power Transformer do in a tube amp?
Transformers either step up low voltage to higher voltage or step down high voltage to lower voltage. You have a step-down transformer somewhere outside your home that reduces the high-voltage line next to your house from 440 or higher VAC (volts alternating current) to 120 or 240 VAC that is used in your home.
AC power is supplier to the power transformer and stepped up to a single higher voltage or various voltages via separate windings in the transformer. The primary winding is the power input side of the transformer, secondary winding is the output side.
Why is a rectifier needed?
Rectifiers convert AC power to pulsing DC power. The AC output of the power transformer is fed to a rectifier tube or rectifier bridge or diodes that convert the AC (alternating current) power to pulsing DC (direct current) power. The DC power pulses because only 1/2 of the sinusoidal AC power wave is converted into DC power by the rectifier. These DC power pulses are smoothed out by the power supply capacitors (see explanation below). The resultant DC power (B+) is then supplied to the anode and cathode (plates) of the tubes.
This AC to DC conversion is required because most parts in a tube amp use DC power.
What purpose do the power supply filter capacitors serve?
Great link on why old capacitors need to be replaced, and which to replace: http://www.antiqueradio.org/recap.htm
Power supply filter caps are polar electrolytics (unlike coupling caps which are non-polar film or paper-in-oil caps) and are wired in parallel (coupling caps are wired in series). The pulsing DC power from the rectifier stage is smoothed out by the power supply filter capacitors to supply consistent DC power to the tubes and other components in the amp. The diagram below shows how the amplitude of the pulses is reduced via the filter caps (and regulator if your amp has one).
One analogy is the power supply filter caps act like the springs on your car that absorb the bumps in the road (pulsing DC power from the rectifier)and deliver a smooth ride (constant DC power) to the passengers (tubes).
@GordonW further explains how power supply filter caps work in this post.
attachment.php
How does a small signal tube work in a tube preamp or power amp?
Signal tubes such as 12AX7s, 12AU7s, 6DJ8s are typically used in the preamp section of an integrated amp to amplify the input source signal. You will also see small signal tubes in standalone power amps too, where they are also being used to amplify the preamp signal.
The AC signal from from the audio source (e.g., CD player, turntable) is fed to the control grid of the small signal tube and modulates the electron flow from the cathode to anode. In simple terms, the AC signal rides on top of the DC power flowing from the cathode to anode.
How does a power tube work in a tube amp?
Power tubes consist of a cathode, grid, anode, getter, heater and sometimes other types of grids. The anode from a small signal tube supplies the slightly amplified source signal to the power tube control grid, which controls the audio frequency and volume output of the amp.
Maximum # of character reach in this post. Explanation of how a tube amp works is continued here.
This and the following thread are fantastic. I need to grab a cup of coffee and pad and start capturing points. Thank you.
Supplemental policies? They're supposed to be honored by any doctor who accepts Medicare.
Now that open enrollment is near, Medicare Advantage TV commercials seem to be more common than injury lawyer ads. There must be a lot of money to be made in Medicare Advantage.
I know from an experience that touching 400V DC will knock your wang into the dirt.
attachment.php
attachment.php
attachment.php
[SIZE=3]BmWr75[/SIZE], thanks for posting this awesome information about tubes. I've wondered for years how they work inside and this is a LOT of info but really great. #MuchAppreciated!​
Jeff R has it right. I touched 400V DC once in a Dynaco preamp and it was worse than 120V AC and 480V AC. The thing is that AC goes through zero volts 120 times a second so it is easier to pull away from. DC is constant and doesn't pulse. It hits you and stays there.
It is a hard lesson to learn.
Wow...what kind of damage did it do to you? Hopefully not much.
