171-150 (P)WORLDS LOUDEST CAR STEREOS, UP TO 80 SPEAKERS,32 CAR BATTERYS,
100,000 WATTS, 125-138 (N)
171(P) acoustic air pressure generator -ref.12
172 (N) 727, 737, 747, 757, 767 CRUSING AT 6 MILES HIGH MACH 0.84, AT THE GROUND (SEA LEVEL) LOSES AN ADDITIONAL 6 DB BECAUSE AIR DENCITY IS ONLY HALF SEA LEVEL AT A HIEGHT OF 6 MILES
172 FOG IS CREATED, DEPENDING ON THE TEMPERATURE, DEW POINT AND HUMIDITY
173-164 (P)BASS INJECTION TESTS, EXPIERIMENTAL ELECTROMAGNETIC TYPE SPEAKERS -REF.1.1987
173(P) = hydraulic, whole body dynamic pressure chamber, at 8 hertz -ref.11.
174 AIR BEGINS TO HEAT UP DUE TO COMPRESSION, MOST SHOCK WAVES ARE VERY HOT
174(P) LOUDSPEAKER COUPLED MANOMETER HEADPHONES DOWN TO 1 HERTZ -REF.15.
175 (N) QUARTER DYNAMITE STICK, VERY CLOSE PRESSURE MAY EXCEED 210 db (P)
175.8(P) 1 TON T.N.T. AT 250 FEET
177 (P) = 2 P.S.I., DAMAGE TO STRUCTURES ARE SIGNIFICANT, 30% SURVIVAL -REF.2.
180 (P) 1 POUND T.N.T. AT 15 FEET -REF.4.
180 (P) = 3 P.S.I., DAMAGE TO STRUCTURES IS CATASTROPHIC, WHEN A SHOCK -REF.2.
WAVE HITS A STRUCTURE ITS MOMENTUM AND PRESSURE MORE THAN DOUBLES, ESPECIALLY AT HIGHER DB LEVELS, DYNAMIC WIND IS ABOUT 103 MILE / HOUR
AND CAUSES A LARGE PORTION OF DAMAGE, 15 % OBJECT SURVIVAL -REF.2.
180 (P) = MOTOR DRIVE COUPLED MANOMETER STATIC PRESSURE, 165 DB(P) UP TO 50 HERTZ, -REF.14.
182 (P) 1 TON T.N.T AT 150 FEET, EXACTLY 182.2 DB -REF.4.
183 (P) = 6 P.S.I. TOTAL DESTRUCTION OF ALL STRUCTURES, PARTICLE VELOCITY
(BLAST WIND) IS 180 MILES PER HOUR. 0.9 MILES FROM HIROSHIMA ATOMIC BOMB
AND 3.3 MILES FROM 1MEGATON NUCLEAR BOMB, LESS 0.1 % OBJECT SURVIVAL -REF.2.
185.75 (NP) 0.375 POUNDS OF T.N.T. RIECHTER -1.5
186.1(P) 1 POUND T.N.T AT DISTANCE OF 10 FEET -REF.4.
187 (P) 1 TON T.N.T. AT 100 FEET, EXACTLY 186.8 DB -REF.4.
190.60 (NP) RIECHTER SCALE 0 (ZERO) EARTHQUAKE
190.60 (NP) 2.0000 POUNDS T.N.T.
191 (N)BOMB-VERY SMALL 1 LB. OR GRENADE, VERY CLOSE PRESSURE MAY EXCEED 210 db (P)
193.806(P) = 1 KILOGRAM PER SQUARE CENTIMETER
193.979(P) = 1 BAR PRESSURE = 14.504 POUNDS PER SQUARE INCH = 14.504 P.S.I.
194.09(P) = 1 (ONE) AIR ATMOSPHERE = 14.6962 POUNDS PER SQUARE INCH = 14.6962 P.S.I.= 1 ATM
SOUND WAVES DISTORT AND ARE NOW DEFINED AS SHOCK WAVES AND THEY BEGIN TO FOLLOW SHOCK WAVE BEHAVIOR. PARTICLE VELOCITY (BLAST WIND) = 590 FEET / SECOND = 180 METERS PER SECOND = 402 MILES PER HOUR. -REF.2.
194.1(P)EXACTLY, 1 POUND T.N.T. AT 6 FEET -REF.4.
195-190 (P) HUMAN EARDRUMS RUPTURE 50 % OF TIME -REF.2.
195.2(P) 1 TON T.N.T. AT 60 FEET -REF.4.
200.59 (NP) 63.24 POUNDS OF T.N.T., RIECHTER SCALE 1
202-198 (P) HUMAN DEATH FROM SOUND (SHOCK) WAVE ALONE. DEATH FROM: SCHRAPNEL AT ANY LEVEL ABOVE 165 DB IS LIKELY AND BEING THROWN (10 FEET PER SECOND) ABOVE 180 DB -REF.2.
205.29(NP) 320 POUNDS OF T.N.T. RIECHTER 1.5
207 (N)BOMB, SMALL SIZED 250 POUNDS, 14 FOOT WIDE CRATER, NEARBY MAY EXCEED 238 db (P) -REF.2.
207.46 (P) = 68.48 P.S.I.= (Q), CRITICAL PRESSURE, THE SHOCK WAVE PRESSURE(P) AND DYNAMIC (BLAST WIND) PRESSURE(Q) ARE EQUAL, LOUDER THAN THIS DYNAMIC PRESSURE(Q) WILL ALWAYS BE MORE THAN SHOCK PRESSURE(P). BLAST WIND (PARTICLE VELOCITY = U) IS 1697 FEET PER SECOND = 518 METERS SECOND = 1157 MILES PER HOUR. 400 FEET FROM A 1000 TON T.N.T EXPLOSION -REF.2.
209 (N)BOMB, MEDIUM 500 POUNDS, 18 FOOT WIDE CRATER NEARBY MAY EXCEED 240 db (P) -REF.2.4.
210 N.A.S.A. 400,000 ACOUSTIC WATTS EXPIERIMENTAL NOISEMAKER 48 FEET ACROSS OF CONCRETE AND STEEL
210.6 (NP) EARTHQUAKE REICHTER SCALE 2.0
210.6 (NP) 1 TON OF T.N.T. and a 23.40 foot crater
212 (N) SONIC BOOM AVERAGE FROM JET -REF.5.
213 (N) SONIC BOOM GENERATES APPROXIMATELY 1.2 GIGAWATTS OR 1.6 MILLION HORSEPOWER -REF.1.2002
213 (N) BOMB 1 TON TNT, 23 FOOT WIDE CRATER OR 175.8 db (P) AT 250 FEET. 213.44 EXACT -REF.1.2.4.
214.09(P) = 10 atmospheres, DB(Q) BLAST WIND = 217.439 DB(Q)
215 SPACE SHUTTLE LAUNCH EXHAUST, APPROXIMATELY 3 MILES PER SECOND
215 (N)THUNDER, THE LARGEST POSITIVE GIANTS. ORDINARY THUNDER 165-180 DB.LIGHTNING STRIKE
ON OCEAN SURFACE 234db (P) AT 2exp-5 NEWTONS PER SQUARE METER
215 (N) BATTLESHIP NEW JERSEY FIRING ALL 9 SIXTEEN INCH GUNS
216 (P) INSIDE A NORMAL CAR ENGINE CYLINDER WITH A 9 TO 1 COMPRESSION RATIO
216.0 (NP)+-0.3 DB 6.5 TONS OF T.N.T. EXACT EXTREMELY ACCURATE HIGH TECH MEASUREMENTS -REF. 8
217.439(Q) = DYNAMIC PRESSURE BLAST WIND FROM A 10 ATMOSPHERE OVERPRESSURE
218.2(NP)sonic boom F-16. at 100 feet high = 3.92 lbs.per square foot = 139.6db, +78.6db = 8536.5 meters high -REF.1.10. 2002
220 (N)BOMB, LARGEST USED IN WWII, WIEGHING 11 TONS AND 25 FEET LONG -REF.1.3. 2001
220 (N)SATURN 5 ROCKETSHIP, MELTS CONCRETE AND BURNS GRASS ONE MILE AWAY
REACHED A VELOCITY OF 5 MILES PER SECOND AND MOON ON JULY 20, 1969
220 (N)SPACE SHUTTLE LANDING SONIC BOOM WITH VELOCITY OF MACH 20 -REF.1. 1998
225 (P) INSIDE A NORMAL DIESEL MOTOR SEMI-TRUCK CYLINDER 25 TO 1 COMPRESSION
226.59 (NP) TRAIN EXPLOSION 2004 FEB 19 09:37AM NEYSHABUR, IRAN, runaway train, possible terrorism, shattered windows at 15 km.,crater is 500 feet diameter and 50 feet deep, magnitude 3.6 riechter, at several miles "the entire area shook", heard at 75 km, equal to 251.195 tons of t.n.t., 51 car train = 17 cars sulpher, 6 cars gasoline, 7 cars ammonium nitrate fertilizer (a.n.f.o.), 10 cars cotton wool, 3 left at station not involved, 8 miscellaneous loads
228.1 (P)EXACTLY. 1 POUND OF T.N.T. AT A DISTANCE OF 1 FOOT -REF.4.
229 (N) SEAFLOOR VOLCANIC ERUPTION, REFERENCE 2 EXP-5 NEWTONS PER SQUARE METER
230.59 (NP) EARTHQUAKE RIECHTER 4.0
230.59 (NP) 1000 TONS OF T.N.T.
232 (N)LARGE NON-NUCLEAR EXPLOSION, 500 TONS, 1917 DESTRUCTION OF GERMAN
WWI TUNNELS IN MESSINES RIDGE BELGIUM, HEARD OR FELT IN LONDON (N) -REF.1.,-REF.3.
234.09(P) = 100 ATMOSPHERES, BLAST WIND = 241.46 DB(Q)
235 (P) 1 TON T.N.T. AT 10 FEET, EXACTLY 235.3 DB -REF.4.
(N)TORNADO AVERAGE, 5100 TONS OF T.N.T. -REF.1. 2004
235.19 (NP) EARTHQUAKE RIECHTER 5.0
235.19 (NP) 31624 TONS OF T.N.T.
240 (N)ONE KILOTON OF T.N.T EXPLOSIVE, 233 FOOT WIDE CRATER 29 FEET DEEP,10 P.S.I. AT 1000 FEET (P), 230 DB AT 10000 FT(N) -REF.2.
240(N)TORNADO, FUJITSU 5, ENERGY GUESS BASED ON 300 MILE PER HOUR WIND, 1 MILE WIDE -REF.1.1997
241.46 (Q) = blast wind pressure from a 100 atm overpressure
243 (N)LARGEST NON-NUCLEAR EXPLOSION EVER, 1947 DESTRUCTION OF NAZI U-BOAT PENS
USED 7100 TONS OF EXPLOSIVE -REF.1. -REF.3.
247 (P) BOMB INSIDE SHOCK WAVE MAXIMUM LIMIT PRESSURE OF T.N.T. EXPLOSIVE -REF.2.4
248 (N)ATOMIC BOMB-HIROSHIMA AND NAGASAKI JAPAN AUG. 6, 9, 1945.TRAGICALLY KILLED
300,000 PEAPLE. TOTALLY DISINTEGRATED 16 SQUARE MILES, CRACKED DISTANT CONCRETE WALLS 12” THICK, EQUAL TO 20,000 TONS OF T.N.T., WIND WAS AROUND 300 MILES PER HOUR, DESTROYED WALLS 28” THICK AT 1 MILE.POWER TO MAKE A CRATER 633 FEET WIDE AND 80 FEET DEEP -REF.1.2.
254.09 (P) = 1000 atmospheres overpressure, dynamic pressure = 261.721 db(Q)
255 (N) 600 KILOTONS GROUND BURST CRATER IS 2112 FEET WIDE AND 211 FEET DEEP -REF.2.
257 (N)NUCLEAR BOMB, 1 MEGATON (1 MILLION TONS OF T.N.T.) -REF.2.
(N)NUCLEAR BOMB "OAK" 8.9 MEGATON, ENEWETAK,JUNE 29 1958,5740 FEET WIDE 204 DEEP CRATER
261.721 (Q) = dynamic blast wind pressure generated from a 1000 atmosphere overpressure
274.09 (P) = 10000 atmospheres overpressure, dynamic pressure = 282.042 db(Q)
278 (N)NUCLEAR BOMB, “BRAVO” TEST 15 MEGATONS, 1954, BIKINI ATOLL, MARSHALL ISLANDS -REF.2.
(N)METEOR HITTING EARTH, “ARIZONA CRATER” SPEED WAS 44 MILES PER SECOND
AND ABOUT THE SIZE OF A HOUSE AND MADE A CRATER ONE MILE IN DIAMETER 20 MT T.N.T.
(N)NUCLEAR BOMB, 20 MEGATONS, SURFACE BURST CRATER IS 7392 FEET WIDE AND 792 FEET DEEP
282 (N)NUCLEAR BOMB, 57 MEGATONS HYDROGEN LARGEST EVER DETONATED, 1961
SHOCK WAVES CIRCLED THE EARTH 3 TIMES, FIRST ORBIT TOOK 36 HR 27 MIN. -REF.2.
282.042 db(Q) = dynamic wind pressure from a 10000 atm overpressure source
286 (N)MT. SAINT HELENS VOLCANO ERUPTION-BABY VOLCANO, BLEW DOWN TREES 16
MILES AWAY. COULD BE SEEN FROM OUTER SPACE ON THE SPACE SHUTTLE
BLEW OUT SOME WINDOWS IN SEATTLE-TACOMA 200 MILES AWAY, 163 db (P) -REF.20.
294.09 (P) = 100000 atmosphere overpressure, dynamic pressure = 302.0488 db(Q)
296 (N)EARTHQUAKE 8.6 RIECHTER SCALE- GROUND MOVED UP AND DOWN 13 FEET. -REF.1.3. 1988
