justinis
I have a custom built tube amp. Schematic attached. I recently noticed it sounds kindof dead compared to other amps. I made a frequency response measurement of it and sure enough, the gain drops from 25 dB at 200 Hz to 22.5 dB at 10 kHz:
How should I begin to diagnose this?
I simulated the entire amplifier in LTSpice. In simulation, the gain is the same at 200 Hz and 10 kHz. However I don't have any parasitics modeled. I am suspicious the problem is related to transformer parasitics. Should I try to model them and produce the rolloff in simulation so I can tweak component values to correct for it? Or is simulation a fool's errand and I should make more measurements of the amp itself to determine where the problem lies?
