I use HPM 100's with great success, albeit somewhat modified from their original intent. I use them in a triamp setup (HPM's get two amps) and they handle everything from 75 Hz on up, with Denon POA 2200/2400 amps powering them. Stereo subs handle the rest. I took the somtimes fatiguing tweeter out and stuck in a Vifa dome (increased the power handling big time, I'd also smoked a tweeter or two in my day, no clipping just too much power!). I've recapped them as well, and plugged up the ports (stops the woofer midrange noise coming out of the port - tightens bass a smidge) , also added additional dampening where the cabinets were lacking. Crossover wise, I'm only using the tweeter, super tweeter portion of the crossover, as the active Xover handles the rest. I use a digital EQ to doctor what I can't do with physical mods. I'm pretty damned pleased with the tunes they reproduce at the moment, the mods, one by one, have each taken these classics to a better place.
I think the speakers are definitely classic keepers, and are alot better than my Minimus 7's, my Advent Legacy's, no comparison. They have some flaws, which I've addressed some of it, but the driver quality, the cabinet quality, are definitely assets one can work with. I think I've tweaked as much as I will do to these units - but if I didn't have some DIY's in the works, maybe I'd keep going!
My only points (if I really have any) is that they can be modded a little (without straying too far from the original look) to become better than stock, and the component quality is there for a good speaker base, whatever your plans are.
Additionally, I have a buddy that has two pairs of these (stock) in his garage hooked to a Toshiba SA7100 and I gotta say these sound great on their own - I think his acoustics are part of this as well though. If you like the sound of your HPM 100's stock, you're not alone, that's for sure. Hey, if you find something better, grab it and listen, if not, keep enjoying these speakers as the original designer hoped that you would - or experiment - it's all good.
