The caps are C100, and the resistor is R100 in the Zobel, if your R is 15ohm, then I'd
suggest you do the cap instead and decrease it rather than increase the resistor to a
size larger then 15 - 16 ohm, I would call that tops.
The cap can be taken down to as low as say 7uf, from that 15uf I stated in the xover.
Yah I'm not sure what has changed that much from the initial turn on till now so far as
the smoothness and non etchyness to vocals ecpesially, I believe it is the selenium to
be the one that has gotten better sounding with a bit of "time" on it, but I'd suspect all
the xover parts as well. Plus that foam does wonders, I'd suggest you try an find some
in your area. (the particulars to the foam are in the Econo thread)
There has definatly been a change to the speakers in there sound from when I first had
bulit them till now, before I'd always had to have the L-Pad down a bit keeping the tweet
a little on the dull side as it was just to hot sounding to the point of being a bit harsh, but
now I can actually turn that tweeter up past being flat without any harshness to it, I have
kept the foam in there though to from the first time I did the testing, it just works well.
There's lots of gear that goes through my system an I know the sound of my test material
I use quite well, I can tell quite easilly when something is not right in here. I was sceptical
for a while with the speakers first into my main system on whether or not I was going to be
able to get these things to sound good enough to stay for any length of time, now they are
right up there with the best of the bunch I've had here if not better for my particular wants
and needs at the present.
If you need to, keep asking questions, I'll help as much as I can.
