The MX119 seems to have possibilities, albeit no room correction, etc, but for the sonics might be an option. The simplicity (or at least more simple/less computer board complexity) might serve me well here, seems less complex in that sense, as I don't need beyond 5.1 or 5.2 (two sub cabs, but they are behind the mains so 5.1 should work with miniDSP running sub EQ). I've also been looking at Anthem AVR 70 and Marantz AV8805 as "latest new" options but I can't get one for a few months so I'm not rushing and just soaking up all the info I can. I figure no need to hurry in the interest of getting it right. I also thought about, if I could get an MX119 reasonably priced that I could turn if it wasn't workable, that this might be worth a try. There seems a lot of possibility there, though......these don't cost what the later Mac HT preamps seem to......
If I had an Oppo 205 I just might be able to work with the C45 albeit the fact that the 5.1 optical outs seen as universal on so much stuff wouldn't 't be so much an option. Stuff like using the cable box 5.1 optical out, or the same out of my Sony display (where I use my computer into the Sony, then 5.1 optical sound out of the Sony to a basic processor) is stuff I really got used to and can separate out aud and vid to do "end around" installs to allow legacy gear and other stuff to work. I seem to need and use the legacy as much as I do the HDMI, and even then not having an issue running HDMI to TV only. It's not super slick convenient, but it works, and I've done it for a decade already.
If I ran a mini-DSP setup on the subs that would be the majority of room correct that I would really need, though. The room correct stuff is nice but I could and would run a DSP on the subs and solve what I really would want solved WRT that issue.
I've slowed down the "pace" and am soaking it all in as I rebuild the Cornwalls step by step. No hurry, deep in the think tank here, contemplating every option.
BACK TO AMPLIFIERS.........
So how reliable are 5 channel Mac amps (like the MC205)? I'm considering two amp options in the realm of Mac:
Use my two MC250s (which I will have electrically restored if I choose this option as they are due) and an added MC2100/2105 (that I would purchase and have restored) to run as follows:
MC2100 or 2105 on mains
MC250 bridged mono to the center
MC250 running the two rears
I have two MC250 now, pretty examples, and would buy an MC2100/2105 and have them completely restored for the long haul. This would cost about 5K.
OR........
I could just buy an MC205 late model and be done with it. One chassis, simple, easy to "own/have around". But it's NOT autoformered (I wonder how much of an issue this really is, especially on Cornwalls where the woofer runs around 3.7ish ohms) where I want the amp to "handle" that properly. I suspect I'll be good with the "Mac sound" in either case - they seem to review well, even for those speakers, but I wonder what those in a Mac centered forum would have to say about the amplifier choices laid out here. Especially for Klipsch Cornwalls and the impedance swing (from high 3 's ohm on the woofer through the 8-12 ohm range moving through the mid to upper freqs....)
The MC205 is also about a $4-5K proposition (and would still have a pair of Mac 250 off to the side, maybe rebuild one as 2 channel backup??)
I KNOW that the old MC250 and similarly autoformered/tubish sounding like amps love the old Klipsch Heritage, and while I'm not adverse to having a more "modern Mac" type of presentation (and in fact might even welcome it as I have a two channel tune system that scratches a bunch of those itches) I'm wondering why amplifier advice and considerations might be offered here for the HT, where the musicality is still a big consideration. The 200WPC MC205 would assure I wouldn't run out of power, but I wonder about how that is at 3 watts, where I know the MC250s do really well on the low to moderate side of the power usage.
Thoughts?
