What?!. No i don't think so!. How do you explain that if you dial in too much AS, the arm returns to rest position!.The spring is connected to a brake shoe that puts pressure (AS) on the pivoting shaft. It's correct length and force can be correctly calculated, measured and put into operation as springs are everyday, all around the world in the manufacturing sense. AT screwed up at its first attempt.
I take anti-skating with a grain of salt. My PL-41 doesn’t have it. Doesn’t need it, sounds excellent.
AR XA TTs don’t have anti-skating either. Apparently they don’t need it.
My RPM3 does have magnetic AS. I use it with a grain of salt. I have numerous LPs that are a bit off-centered. I can watch the tonearm move back and forth. One more reason to take AS with a grain of salt.
Then, you have sufficient VTF to track and trace the groove and overcome skating force.My older (circa 1980) AR TT (Sumoko arm + Shure V-III + Shure styli only) has never "skated" 'cross a single "single" (45) or LP (10" or 12"). Not even once.
I wouldn’t use the term “gimmick”. The design seems reliable enough. It’s going to be less accurate over long enough time, but simply adjusting it will compensate and it should be fine given the inherent imprecision of skating.I always thought that a spring anti-skating was gimicky, compared to a weight/ string or a canti-lever one. Spring tension changes with time and are in-consistant, what do you guys think?
As you can see from the graph (from Shure); Skating decreases as the tone arm travels across the record with a slight increase at the spindle.This is the type of AS i mean, a mechanical one, that's consistent over time (no springs). I my opinion, these types were calculated (the angles), to have a greater AS effect as you get near the spindle, what do you guys think?
Good if friction drag is low, most examples I've seen were low drag.This is the type of AS i mean, a mechanical one, that's consistent over time (no springs). I my opinion, these types were calculated (the angles), to have a greater AS effect as you get near the spindle, what do you guys think?View attachment 1659329
I believe this mechanism (e.g. Yamaha) is designed to follow exact graph by Shure brothers.This is the type of AS i mean, a mechanical one, that's consistent over time (no springs). I my opinion, these types were calculated (the angles), to have a greater AS effect as you get near the spindle, what do you guys think?View attachment 1659329
