I recently purchased a Lafayette LR-5555. I initially cleaned it and checked for DCV on the outputs. Everything seemed ok so I used it for a couple of days while I waited on new power supply caps. It worked but seemed a bit anemic. So I replaced the caps without taking any voltage readings first. After installing the new caps I had 42vdc and -53vdc. By the way both caps had dropped to 6000 mfd from 10000 mfd. I have gone as far as disconnecting everything from the power supply and installing new rectifiers. I have 32vac on both taps of the transformer and after passing through the rectifiers it’s unbalanced even before going to the filter caps. If I remember it was 24vdc and 28vdc or there about. After hooking up the filter caps it’s 42vdc and -53vdc. There’s nothing else in the circuit but the bleeder caps and they are both 1.5K ohms. Any ideas. I’m stumped. The rectifiers are all good. The only thing I can think of is a bad transformer but it reads balanced at the taps.
