epifanatic
acoustically suspended
Oh man!! This is going to be good.
Dammit Mark.......you took a photo of my bad side.
QUOTE]
ROTF, I was lookin' at the tester Scott... Really great score Mark! All Mullards that are in good shape, too. :yes: Sweet!!
If you were to paint it I would choose a gloss white - would project a sense of sterility and help to draw focus to the amp. And, if you do paint I would also put the amp up on some blocks to help disapate the heat of else the heat may bubble the paint.
Make sure your ventilation scheme has redundancy. Those holes are in that back cover for a reason. :yes:
If anything I would paint just the horizontal surfaces, shelf support, and back shelf edge all flat black. I might put a few coats of shellac on the inside side walls.
Okay, this has been operational for a while and, as I explained earlier, I have to keep it in the cabinet it I want the tubes to survive in my house. It just kills me though that the beautiful power amp can't be seen.
So I came up with the idea of replacing the pegboard on the back with plexi glass (see page one of this thread for pics of the cabinet). For ventilation, I am considering two port tubes extending from the plexi surface to the back (or is it the front?) of the cabinet. Then I will use a very quiet computer fan to draw air out from the middle of the plexi.
There is one detail I can't make up my mind on. That space is unfinished and looks awful. And the wood is too stained to finish it to match the outside of the cabinet. I think I am left with little choice but to paint that cavity. I was having a hard time trying to visualize how this would look, so I Photoshopped a few swatches. Of course, this is only an approximation, but the four shown are my two favorites and my wife's two favorites. Which do you like? TIA
I'm sure it will be but that wasn't what I was getting at.I feel certain that a fan will be more efficient than a bunch of holes operating passively.Make sure your ventilation scheme has redundancy. Those holes are in that back cover for a reason. :yes:
Then I would need 3/4" plexi for in front of the amp to keep things uniform. I imagine that would be both expensive and difficult to work with. Plus probably not optimally clear. I'm not sure though.
