Hello, I am officially a member of this group!
I won a pair of IMF TSL 50 II’s from an estate auction a couple weeks ago and they were delivered today.
They were listed as “house speakers” and I was lucky enough to think they looked familiar. I dropped a $50 max bid and won, $40 including auction fees and taxes, then after spending several days reading this thread, decided it was worth spending $240 to have them shipped from Indiana to Massachusetts.
Unfortunately they are R O U G H
I have to assume they passed through several hands of teenagers or goblins who have never heard of a soldering iron before they were picked up by the collector/repair shop that was the source of the estate sale.
Bad news:
One Audax tweeter is missing
The other Audax has broken leads and the plate is warped from over tightening or meth rage idk
one Coles tweeter measures open, is missing the plastic dome and makes no sound
The other Coles has a missing lead… it’s just snapped-off or something
due to the failed/broken/removed high frequency drivers, someone decided to drill holes in the back and run wires to an external tweeter that was screwed into the top of both cabinets
multiple threaded screw receivers are missing or pushed out, random assortment of hardware used to hold drivers in place.
Middling news:
The Kef drivers don’t match, but they work!
One of the Elac mids has a dust cap that says “Bose”
Good news:
They actually sound decent, despite having no measurable sound above 8k and the bass is flabby with open holes in the baffle — but I can hear the potential!
Weird news: someone took the grill off of an ADC 303ax, cut it down, turned it 90 degrees and attached it to cover their shameful handiwork. (I have two matching uncut grills already, so the coincidence is … interesting)
So far I have removed all of the weird wires spliced with electrical tape (except for one where the wires were cut too short, I’ll need to get crimp-on connectors there until I am ready to trace the wires back to the crossover and run new wire).
The plan is to get them sounding right, then figure out how to make them look better. Idk if they will require a full re-veneer or if sanding, filling and varnishing will be sufficient. Might make grills?
the Audax tweeters need to be replaced —
These ones from Madisound have a different model number from Falcon, but they look nearly identical?
https://www.madisoundspeakerstore.c...-12x9-1-textile-dome-tweeter-with-ferrofluid/
the coles super tweeters: how likely are they to be repairable? Is it even something to consider? I have seen the comments about their fragility. Is the only source falcon, are there alternatives?
My target isn’t factory-correct, maybe factory-adjacent? They won’t be in the living room so, WAF isn’t strict.
