Yes, these speakers require the 8 ohm version to perform as intended. The pair I have need to be converted to 8 ohm with the proper voice coil.
I just received this message back from my inquiry to the seller:
"Hello, I did not understand your two messages. If you have tweeters under 8 ohms, you must take diaphragms under 8 ohms. If it's 4 ohms then stay under 4 ohms. Regarding the product, the diaphragm is a dome and a coil. cordially"
So it appears that I have the dome and the coil, although the combined unit is not much bigger than a nickel, in diameter, and three times thickness. So it seems I have what would be needed? However, with not being able to find any audio repair shop that will perform the work, I think I have essentially thrown away the $90.00 and still need to find two 8ohm tweeters.![]()
I used the same voice coil for my HF-1300 but it was the 4 ohm version.
Here is the start of my repair. you need to use the original dome. I did this a few years ago but know
I could do it again.
https://audiokarma.org/forums/index...storation-to-begin.701209/page-2#post-9498299
EDIT: Was this the voice coil you bought?
https://www.ebay.com/itm/325140476554?hash=item4bb3e1f28a:g:LnAAAOSwu1VW4Vaf
Athanasios
