These have definitely not been re-capped. They are all original. I know that received wisdom has it that speakers of this age will benefit from a recap. However, I have recently restored two pairs of ARs of similar age. In both cases, I took the speakers to my local tech to get the crossovers tested and the caps all measured within spec.
I will be buying a crossover kit from Falcon Acoustics in the very near future but I'll probably just put it in the cupboard for a while. Given the originality of the IMFs, and my experiences with the ARs, I'm thinking of leaving them as they are for a little while. My ears are telling me that the crossovers are still good. They image well, the treble is sparkling and the midrange is in no way recessed. That said, a friend of mine is good with a soldering iron and has offered to recap them for me. How easy is it to access the crossover on these speakers? Is there any great risk involved in letting my friend loose on them?
Edit: Do you know if any of the caps are electrolytics?
Right, and I'm certainly not going to discount your technician's or your own personal experience. I used to think along the same lines, if they test fine, don't replace them. What I've learned though is that you can't simply test the capacitors for just capacitance, you have to test for ESR as well which is a much bigger indicator of their performance. ESR is a tricky thing to test as well - so it's almost pointless to bother and it's much more practical to simply replace the parts.
I'm also certain your ears are not lying to you and that the speakers do sound good. Many things depend on how the capacitors age - environment, heat (caused by high wattage), amount of use, etc. Likely the pair you have has been played at low volumes in a good environment. However, the capacitors are bordering on 40 years of age. Regardless of how good they sound now, they don't sound as good as they did 40 years ago. I say this with certainty because I've replaced Elcaps (the brand of capacitor in IMFs and other british speakers of that era) in about a dozen speakers, half of those being IMFs, and each one made a marked improvement in performance. This is why I stress to do it because you aren't hearing what they really sounded like until this is done. I've also read of accounts where folks recapped them and heard no improvement - I find that unless you do an A/B with one recapped and one all original, you aren't going to be able to detect the difference or know if there is one, and in most cases where I've read of this the DIYer recapped both at the same time and then fired them up.
Anyway, I don't mean to ramble here. I understand you plan to recap them anyways, so I'll answer your questions.
Recapping these is a cinch - the crossover is accessible through the Kef B200 bass driver. Simply take it off, and you will have the crossover there. I am not familiar with the internals on that model so I don't know how long the wires are, but my recommendation is if it is feasible, to keep the crossover wired in when recapping. Otherwise you are faced with resoldering 12 wires to the crossover board and this is time consuming, tedious and tricky.
As far as risk goes, unless your tech isn't very careful, then there shouldn't be any problem.
Yes, there are electrolytics on the crossover. Most of them are. I have not seen that crossover myself, so I can't say with certainty what exactly is on there but expect the majority to be Elcap electrolytics. The kit from Falcon Acoustics will contain all the capacitors you need to successfully recap them. One thing to keep in mind as well, if there is an attenuator control on the back, there will be capacitors on there as well.
I hope that helps. If you get a chance to, have your technician listen to one speaker all original and the other recapped and have him report to you the improvement. Otherwise you won't know where your money is going.
If you have any other questions please feel free to ask.
OH.. and I want to mention.. go with the Falcon kit - don't bother with anything else. I know you said you will but I say this only because I don't believe in "upgrading" crossovers by replacing electrolytics with poly capacitors and such mods like that. I have found that they change the character of the speaker and delineate from what they originally sounded like which to me is a useless exercise in attempting to get better sound. They were good 40 years ago, they'll be good today.
