mccarty350
Ordered a full roll and cut it down myself. Lots of extra in case a mistake occurs in cutting.
Sent from my SPH-L710 using Tapatalk
Thanks Canuck, ended up passing on it, and sold my separates. Just going to run my AVR for now, ultimately based on A/B results it runs these guys really well, tight bass, with a nice crisp punch to it. The 30 year newer amp just worked better.
Next project, sub in my hiquphon for either the HF or Super tweeter, not sure which one yet. The frequency range would likely be best for the HF KEF driver. One of the things about the hiquphon sense of air and space, which leads me to want to swap out the super tweeter, but it "only" goes to 20 Khz, but what I don't want to loose on the IMF is that rock solid imaging. Will report back results.
At some point I figured the vintage linn hiqophon,I have 2 sets, was similiar to the http://www.hiquphon.dk/page14.html#Technical data OW II (D2094-9008-03)
Here's a photo of one of my restored/poly'd cabs. The other is sitting around with paint stripper. This is sans foam grills and the foam covering the transmission lines.
Added a before shot for comparison.
Read through this entire thread tonight ... Whew! A wealth of information. Just thought I would check in as an Ottawa IMF enthusiast.
I'm currently finalizing restoration of a pair of TLS50 Mk.1. I have also restored the SuperCompact II, ALS40, and RSPM IV models. Still have them all.
Thanks guys, I just want the caps to come in. I figured I wouldn't hold back on these, they get the full restoration treatment.
I am particularly looking forward to hearing about your experience with these after they are restored electronically :yes:
By the way, just as a note on placement, give them space and distance if you can. The 4-way drivers don't gel together until they get some distance away. I've got mine roughly 10 feet away, but they have worked at closer distances like 7-8 feet. If I recall correctly, you've got just about the perfect sized area for them to work.
Those are TLS 80s.
Nice speakers! Thank you for sharing the pictures with us
John - they like to be away from walls. Corners amplify the bass and make them sound a bit boomy.
