captouch
Addicted Member
Yippee, got my caps today - now one question. I will obviously replace like for like (and as you have suggested, replace only the originals, leaving in any modified caps that goes with the replaced drivers) BUT, does these caps go any direction, or do they have a + and - side?
Any other pointers would be appreciated. I have never done this before, but have soldered in the past.
These are non-polar, so no +/- side. I put mine in with all the writing in the same direction, just because.
Take your time, try not to keep your iron on the joint (whether desoldering or soldering) longer than is necessary to melt the solder. . .all the basic stuff.
I found my new caps had slightly thicker leads than the originals, so I had to use an icepick to gently enlarge the holes to allow the new leads to go through. Otherwise, it was quite straightforward. I was able to access the boards without desoldering any of the speaker leads from the crossover - this saved some time and hassle of dealing with more wires to be removed and reattached.
Double check your other solder points while you're in there. Touch up anything that looks marginal.
) the holes in the boards behind the speaker interconnect lugs was too small for the new caps, but fortunately .... I had a heads up
