ken kantor
Fowl Humor
When Ken Kantor comes, he asks nasty questions that no one can answer. Let's face it, there is no detailed acoustic analysis of a fiber filled tube. Bradbury is the most complex that I have seen. He made many simplication and did not try to integrate the analysis with a driver due to the complexity. He pointed out the simplication in very fine details. He was able to predict the sound propagation velocity and small signal sound absorption by assuming 1-D oscillatory flow in limited amplitude. That allowed him to formulate his "aerodynamic drag" theory as purely potential flow. Therefore, there is no "viscosity, hysteresis, stiction, collisions, etc." involved. It is amazing how well his theory agrees with experimental data on fiber filled tubes.
Others assumed simple minded adiabatic or isothermal interaction or some mixture of the two between air and fiber. But no perfect coupling of air and fiber exist in nature. I will quote A.R Bailey in one of his reply to letter to editor from the 1965 paper.
We only know that 1-D wave equation coupled with driver filter model does not work well for transmission line, partially due to the nature of frequency dependent response of the TL line at the line terminus. Bradbury presented an example of limited small signal analysis that showed good promise. But after 38 years, there is no extension of Bradbury's work.
Ken, I will throw this back at you. What is your suggestion in term of testing and analysis for TL speakers? So far, the only thing that works is by trail and error.
Sorry. TL speakers are not my area, so I can't contribute anything very meaningful. If it were me, I would only do the obvious things: pull the design into an FEA package, start with standard materials properties, then iterate until I had an acceptable match with physical measurements. I would do my best to ignore prior art and focus on first principles. Where these were obscure, I would experiment, consult prior art, and talk to non-audio acoustics experts I know. But, as I said, Transmission Line Speakers are not really my thing. Yes, I have used TL theory to solve some very specific acoustical problems. But, these were special cases, and not at all like the kind of speakers you are discussing.
Audio technology is different than any other type of engineering I know of. In normal engineering, we start with a certain problem, and then try to invent a solution to this problem. But, in audio, most of the time, we start with an invention. Then we try to discover what it might be good for. However, just because one has a cool invention does not mean that the invention is useful or any improvement to the art. I see a little bit of this problem with transmission line speakers. Certain people invented a new way of dealing with a driver's rear radiation. Extremely clever, I admit. But, why? What does a TL do that cannot be done other ways more easily? (This is an honest question!) Of course, as just about anything in audio, TL fans will show up to exclaim that the sound of TL's is magical and different and cannot be achieved any other way. But that's just a religious belief that doesn't explain anything one way or another.
Sooo.... now that I have two of the top experts in the field available, and especially two who can talk in real scientific and engineering terms, what do you feel are the technical advantages of Transmission Line loudspeakers? (I promise I won't argue or debate, I just would like to know.)
-k
