Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I found a short thread postet 2009 to which Avionic responded, saying that the guy should switch the probes because this values were printed when analog multimeters were standard. So I will adjust to -2.5V and enjoy my B-6.
? Negative Idle current on Yamaha M-50 ?
Was it you or Asmo looking for a new speaker relay? Schrank PT270024 fits, I use it in my B-6.
In all amplifiers I have adjusted it was the case that turning the trimpots clockwise increased the bias. In the B-6 it should be different? I am asking myself if the SM is wrong.
I am seeking some assistance on making adjustments on my M-50. Following the service manual, to measure/adjust idle current, the (+) lead goes to "TPO" and (-) lead goes to "TPE ". With this connection I'm measuring about - 45mV on each channel. A negative value ?? Is there something...
audiokarma.org
Now I have to open up my B-6 for the third time!!!
And I too have those Mundorf caps , I have 4 I was going to use them in my B-1 but everyone here suggested they aren't the right physical size to handle the output of the B-1 .
Three times is nothing. If you are successful squeezing the Mundorf 15.000 uF caps in, please post the procedure.
Regarding the relay, the brand name is Schrack, of course. I got it from Farnell.
Three times is nothing. If you are successful squeezing the Mundorf 15.000 uF caps in, please post the procedure. Regarding the relay, the brand name is Schrack, of course. I got it from Farnell.
